Old 05-31-2023, 09:36 PM   #1
bgarrett
bgarrett's Avatar
Default strange serial number
What can you tell me about this serial number? its 3318-1426579
thanks
bgarrett is offline   Reply With Quote
Old 05-31-2023, 10:27 PM   #2
petehoovie
petehoovie's Avatar
Default Re: strange serial number
thanks
Old 05-31-2023, 11:13 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
thanks
Rather than a "33I8-", that is more than likely a "BBI8-I426579". BB usually equated to big trucks, I thought through '34, but the 1426579 falls into the 1935 time frame.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 06-01-2023, 06:55 AM   #4
Model51
Model51's Avatar
I agree, sure looks like "BB18-1426579" to me. The engine-transmission serial number indicates a late January 1935 completion, so a Model 51 truck of some sort.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 06-01-2023, 09:04 AM   #5
rotorwrench
rotorwrench's Avatar
The BB designation was a truck designation but it also designated a 4-speed transmission if installed in a 1/2-ton pickup or a larger truck.
Old 06-01-2023, 09:09 AM   #6
bgarrett
bgarrett's Avatar
thanks guys, I should know that it was BB and now I can see it. This 1 1/2 ton truck has removable door window frames (garnish mouldings) and 1934 door strikers. I am holding an aftermarket striker for 1935 and you can see the difference
Old 06-01-2023, 09:10 AM   #7
bgarrett
bgarrett's Avatar
And the title says 1934
Old 06-01-2023, 10:09 AM   #8
Karl Wescott
Karl Wescott's Avatar
Re strikers: Ford used several different sized strikers, the one from your truck is the 1935-39 "short door" used on pickup, 5 window, and fordor (it was also used late 1931-34).
The repro striker is for a "long door" 3 window or tudor sedan. Note in 1937-38 there was a variation of the striker that was rubber cored and sheetmetal clad. Not one of Ford's better ideas.
Re title: It was common practice until the mid 1930's for some agencies responsible for issuing the title to do so based on when the title was issued as the concept of "Model Year" was in its infancy. It is conceivable to me that if the title application was made on December 31 a 1935 model could receive a 1934 title.
Karl Wescott is offline   Reply With Quote
Old 06-01-2023, 11:12 AM   #9
petehoovie
petehoovie's Avatar
Old 06-01-2023, 01:30 PM   #10
ford38v8
ford38v8's Avatar
This is exactly how it happened at least in California, and the same was also true for an earlier model having a later title. I once owned a 1942 Pontiac titled as a 1943.
Alan
