Old 08-01-2013, 06:24 PM   #1
mikhett
Default Holley 4000 teapots who rebuilds em?
Im looking to have my holley 4000 carb rebuilt.Who rebuilds them.thanks.Can i use a pertronix on the stock dizzy with this carb?
mikhett is offline   Reply With Quote
Old 08-01-2013, 07:43 PM   #2
franksford
Default Re: Holley 4000 teapots who rebuilds em?
The Daytona parts company is about as good as it gets. They have done several 2x4 and a couple of blower 4000 carbs for me. Frank
franksford is offline   Reply With Quote
Old 08-01-2013, 08:14 PM   #3
NH Ford nut
Make sure you have your throttle shaft(s) rebushed also.
Not too many people do this.
Good luck.
NH Ford nut is offline   Reply With Quote
Old 08-01-2013, 08:52 PM   #4
JeffB2
JeffB2's Avatar
Click on this:http://fordbarn.com/forum/showthread...=teapot+holley Then scroll down to post #6 this is who you want to work with.
JeffB2 is offline   Reply With Quote
Old 08-02-2013, 01:42 AM   #5
JeffB2
JeffB2's Avatar
As far as Pertronix goes you might want to look at this:https://www.google.com/search?newwin...09.HXcBVGIAADg I would think a more reliable conversion is using Ford's DuraSpark since parts would be readily available at any local corner auto parts store which is not the case with Pertronix.Contact this member: http://fordbarn.com/forum/member.php?u=3183 to have it done and refurbish your Load-O-Matics internals and set the curve.
Old 08-05-2013, 10:32 AM   #6
scicala
scicala's Avatar
I have been doing Holley 4000 teapots since 1968, along with all other domestic carburetors. I will definitely under cut Daytona's prices without sacrificing quality. I'm aware of any natural flaws on these carbs and make sure they are repaired correctly. Fully guaranteed also. 002.jpg
Picture 006.jpgI will do anything from a spot repair to normal rebuild or show resoration. Whatever you need. I will try to attach a picture or two of my work, and can supply references if needed.
Let me know if you are interested and we can discuss. Sal Cicala (586) 612-1650.
Thank you,
scicala is offline   Reply With Quote
