Old 04-17-2024, 06:21 PM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default master cylinder
I just put a new master cylinder on my car. I have one fitting that weeps. is it safe to put a sealer on the threads. Thanks
bobsmanstuff is offline   Reply With Quote
Old 04-17-2024, 06:30 PM   #2
swedishsteel
Default Re: master cylinder
The threads don't seal on brake lines--the double flare on the end of the tube seals against the female fitting. It might seal if you tighten a little, or there might be a small piece of dirt on the flare, or the flare itself might have a burr or imperfection. Trying tightening first.
swedishsteel is offline   Reply With Quote
Old 04-17-2024, 06:36 PM   #3
bobsmanstuff
I've tightened about as tight as I can get it. I do understand what your saying.
Old 04-17-2024, 08:31 PM   #4
Krylon32
Are sure your fitting is contacting the flare inside the MC?
Krylon32 is offline   Reply With Quote
Old 04-17-2024, 08:33 PM   #5
GB SISSON
GB SISSON's Avatar
I'm afraid you are going to have to take it apart and get to the bottom of the problem. Without the dual master we need to be extra careful. I tend to use the tubes they stock at napa as I have flared a few leakers with my inexpensive kit.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 04-17-2024, 10:11 PM   #6
fordor41
fordor41's Avatar
I've had leakers and I loosen and tighten a few times(3 or 4). that usually stops the leak.
fordor41 is offline   Reply With Quote
Old 04-18-2024, 06:39 AM   #7
bobsmanstuff
It is a duel cylinder that I have taken out once already. I'm going to take it out again today and check the flare. I have a feeling it's a bad flare. Thanks for the info I appreciate it.
Old 04-18-2024, 08:04 AM   #8
jimvette59
jimvette59's Avatar
Are you using double flares ?
jimvette59 is offline   Reply With Quote
Old 04-19-2024, 05:44 AM   #9
Ggmac
Some Dual master cyls need an adapter .
Old 04-19-2024, 06:18 AM   #10
glennpm
glennpm's Avatar
Yes, not all master cylinders have “Inverted Flare Female” IFF machining. Some use 1/2"-20 and/or 7/16"-24 straight threading. These connections use a copper sealing washer between the master cylinder and the fitting. This fitting will then accept IFM - meaning “Inverted Flare Male”.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source for the 1932 thru 1953 Flathead Ford
Old 04-19-2024, 08:52 AM   #11
bobsmanstuff
Thanks for all the help. I used a different line and flare and it stopped the leak.
