Old 09-06-2018, 11:25 PM   #1
Standing Elk
Default Might have screwed up
Not sure but I may have screwed up . I removed my crankshaft pulley nut with my air impact gun. After I did, I got to wondering if I may have damaged the rod bearings. I did not rattle on it very long before it came out but now I am concerned. Should I be?
Standing Elk is offline   Reply With Quote
Old 09-06-2018, 11:32 PM   #2
Drive Shaft Dave
Smile Re: Might have screwed up
I doubt that you hurt anything.
Drive Shaft Dave is offline   Reply With Quote
Old 09-06-2018, 11:35 PM   #3
CWPASADENA
CWPASADENA's Avatar
Default Re: Might have screwed up
The crank has a lot of mass to it and the rod bearings will be fine.
If the flywheel was still attached to the crank, the rod bearings would not even know something was going on.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 09-07-2018, 08:08 AM   #4
Standing Elk
Thanks fellas
