11-27-2022, 02:44 PM | #1 |
40-41 rear pickup window gasket
Is there a preference with truck rear window gaskets? I have one from the mid 2000s from Drake that I have been trying to install my rear glass for almost 3 hours to no avail. It just seems the gasket is too big - you pickup guys - where to you get your rear window gasket from?
Thanks ….. |
11-27-2022, 03:38 PM | #2 |
Re: 40-41 rear pickup window gasket
Tom, I'd used a Carpenter gasket a few years ago when I'd restored my '40 pickup.
11-27-2022, 04:04 PM | #3 |
I also used a Carpenter kit in 2005 that included the rubber for both front windows and the rear window. C&G shows a rear window gasket on their website. It might be worthwhile to check with them and compare dimensions.
11-27-2022, 04:05 PM | #4 |
I don't know about over there but here in the UK it is possible to buy generic rubber seal by the length.
The one top right fits the rear windows. I also used it around the front windshield, retaining the special sections on the central part only. |
11-27-2022, 04:42 PM | #5 |
Thanks gents!
11-28-2022, 10:39 AM | #6 |
11-28-2022, 09:37 PM | #7 |
I also used Dennis Carpenter for front and rear glass, fit perfectly. Front was a pain and took LOTS of soap.
I did it in 2020 if I remember correctly. |
11-29-2022, 06:21 AM | #8 |
Thank you TJ and Oldtimer ….
