01-04-2011, 07:57 PM | #1 |
Ford Transmission Shipping
I recently sold an early Ford transmission. Any tips on the most economical way to ship it?
01-04-2011, 08:10 PM | #2 |
Re: Ford Transmission Shipping
you could ask Greyhound Bus Lines if the oil was drained and if it were put in a crate w/ the shifter off.......Fed EX may also ship in a wooden crate...I shipped a deck lid across the country and they put it in a box length-wise to new york....also shipped fenders via greyhound to penn.. good luck
01-04-2011, 09:11 PM | #3 |
Deuceman,
For what it is worth I ship a 3 or 4 transmissions a month and here's how I do it.... I get a large plastic tote with a snap on lid....usually about $8.00. I cut a chunk of 3/8 plywood to make a floor in the tote....kind of spreads the weight out. I then block the trans in place and drill 3/8 dia holes thru the plywood floor and the bottom of the tote on either side of the trans in the front and back. I fasten the trans in place with heavy duty cable ties...the ones that zip up and lock in place. I run the cable tie over the trans and out the holes in the bottom and back up thru then zip the whole gamash together. This hooks the tote , the plywood floor and trans together nice and snug. To secure the lid in place I drill (8) 1/4 holes around the perimeter of the lid and lip of the tote and use smaller cable ties to fasten it in place. Total cost is $12- $15 and about 1/2 hour. I use Fedex ground it's the best service for the money. Grey- hound is good but sometimes the weight is an issue. Fedex ships out of any Fedex Kinkos store. Charlie ny |
01-04-2011, 10:52 PM | #4 |
I shipped a complete front axle from spindle to spindle with wishbone on Greyhound from Missouri to Florida. Just wrapped the sharp corners and hung a wire tied tag on it. Went right through.
bill |
01-05-2011, 07:40 AM | #5 |
Recently,a guy in southern California shipped me a 1936 Ford tranny.He boxed the trans in a similar manner as mentioned above and Fed-Exed it to my shop.The cost was reasonable(at least by today's standards).
01-05-2011, 09:04 AM | #6 |
ended up being three boxes though; 1-tranny 2-shifter 3-all other parts A little bit of work, but it made it possible to go through the US Mail, which is the cheapest way to go where I live. |
01-05-2011, 09:42 AM | #7 | |
01-05-2011, 10:01 AM | #8 | |
Charlie: Quick note on FedEx. Not sure if you know this or would like to, but you can set-up an account with them on-line @ Fedex.com. It works great, you get a little discount on shipping, plus & this is a big plus, they come to your house/garage/business and pick it up when you schedule it on-line. They also provide you with all of the shipping slips/forms/sticky envelopes with clear face so the packing ticket shows outwardly. I've had an account for about 2 years and it has saved me countless hours having to truck stuff to their depots to be shipped out. Just something that I thought may help you out since you mentioned you do a lot of shipping each month. Best of luck & see you at '11 Hershey. Tim |
