07-28-2014, 04:28 PM | #1 |
driving with front windshield open
I drove with mine open about 2 or 3 inches at around 35 mph
and though my wheel bearings were screaming for help , then only to find out closing the window the noise came from it. is this normal for this to happen? fred |
07-28-2014, 04:39 PM | #2 |
Re: driving with front windshield open
That's strange, I drive all summer with it open, at speeds up to 55mph, and have no squealing noise. Do you have something loose or dangling or in the air stream that would cause it ? How's your visor? Could air be coming thru or around it?
07-28-2014, 04:40 PM | #3 |
not normal ,open till the pins are in the notches,Henry recommends a inch and one half,Sept. !928 service bulletin.
07-28-2014, 05:07 PM | #4 | |
and see if that is the cause. fredski |
07-28-2014, 05:26 PM | #5 |
I never experienced any noise like that with the windshield partially open on my town sedan.
07-28-2014, 05:56 PM | #6 |
no noise in mine thats cool you have a built in deer whistle deterrent... Last edited by Mitch//pa; 07-28-2014 at 07:24 PM. |
07-28-2014, 06:44 PM | #7 |
I ask my wife if she wants to use the "AC"? Usually it is a go and out goes the windshield to the first notch -
Thanks again Henry and Edsel - Be well - SHEC |
07-28-2014, 06:52 PM | #8 |
I keep mine open most or all the way to the end of the retainer with no particular noises.
07-28-2014, 06:55 PM | #9 |
Mine whistles also. I've tried different openings notch between notch's no difference. Since there is no easy answer I'll look further. If I find a solution I'll let everyone know. This has to be happening to others also.
07-28-2014, 07:39 PM | #10 |
My 28 tudor, 6/1/28 Does not have notches.
07-28-2014, 08:26 PM | #11 |
If my window is almost closed it will whistle. On the notches it is fine. I never drive with the window full open.
07-28-2014, 08:30 PM | #12 |
Mine whistles at certain speeds also. I at first thought it could be bearings. I figured out it was the windshield. It doesn't bother me that much.
Ryan Scardina Livingston, Louisiana 1930 LSU Model A |
07-28-2014, 10:07 PM | #13 |
Mine squeals if open as per the service bulletin. If I open it to the maximum, all is OK.
07-29-2014, 05:18 AM | #14 |
On my '31 coupe, the lower edge hits the gas cap when I swing it open. But then if I haven't tightened the knobs enough, when it swings in, the cap doesn't stop it. Is hitting the gas cap normal?
07-29-2014, 06:13 AM | #15 | |
Tom.............. |
07-29-2014, 06:22 AM | #16 |
the w/shield frame should not hit the fuel cap. some but not all causes are loose w/ shield hinge screws, rotted header wood or a hinge gasket that is to thick.
07-29-2014, 07:28 AM | #17 | |
it served a purpose. fredski |
07-29-2014, 03:07 PM | #18 |
My Cabriolet whistles over 35 MPH with the windshield open to the notch. I know what it is so I don't let it other me.
'31 40B '31 68C |
07-29-2014, 03:08 PM | #19 |
Bother no other. I detest autocorrect.
'31 40B '31 68C |
07-29-2014, 04:21 PM | #20 |
I had a windshield that wouldn't open with the gas cap on so I removed the after market gas cap and installed a original and there was plenty of clearance.
