Old 05-27-2013, 01:37 PM   #1
springerpete
springerpete's Avatar
Default Backfire when shuttng off.
Has not done this for quite some time. But today it started doing this again. Not every time. Seems as tho' it like to surprise me. Is there a cure ?
springerpete is offline   Reply With Quote
Old 05-27-2013, 01:42 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Backfire when shuttng off.
Try turning off the gas and let the carb run low or out of gas.
Old 05-27-2013, 05:05 PM   #3
Rock Hornbuckle
Rock Hornbuckle's Avatar
I shut the engine off by putting it in gear with my foot on the brake and let the clutch out slowly.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 05-27-2013, 05:10 PM   #4
700rpm
700rpm's Avatar
I would worry about damage to the clutch disc or pressure plate. Doesn't your key work?
Ray Horton, Portland, OR
Old 05-27-2013, 05:17 PM   #5
Mitch//pa
make sure your not idling to high, also try retarding your spark lever before shutdown
if you have to shutoff your fuel to prevent backfire its masking another issue
Old 05-27-2013, 05:22 PM   #6
William Kelchner
William Kelchner's Avatar
Smile Re: Backfire when shuttng off.
I finally adopted what was mentioned above -- close the fuel valve and let it run out of gas - somewhere between 1-2 minutes. No more embarrassing BOOM.
William Kelchner is offline   Reply With Quote
Old 05-27-2013, 06:05 PM   #7
Patrick L.
Patrick L.'s Avatar
I shut the fuel valve before shut down, push the left lever up and turn off the key. That said, it should shut down without a backfire without going thru any rig-a-ma-roll.
Old 05-27-2013, 06:18 PM   #8
ba49
Check and see if the bolts are loose holding the carb to the manifold. I just went through the same thing and the bolts were loose. Also if your running a tilitson carb, make sure it's not warped at the manifold.
ba49 is offline   Reply With Quote
Old 05-27-2013, 07:20 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
An occasional shut down POP is great FUN! "WELL, I hear Ol' Bill, back from shopping"!-----Boy! It's hard to get a Dog knap! Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 05-27-2013, 07:40 PM   #10
dmaxweb
dmaxweb's Avatar
Condenser
dmaxweb is offline   Reply With Quote
Old 05-27-2013, 09:03 PM   #11
Duffy1
Do a search . A lot of info on this subject.
Duffy1 is offline   Reply With Quote
Old 05-27-2013, 09:11 PM   #12
Tom Wesenberg
Originally Posted by dmaxweb View Post
Condenser
The ignition, including the condenser, is out of the picture once the key is turned off.
Raw gas hitting a red hot spark could cause a backfire. My Cub Cadet would always wait about 15 seconds after shut down, then give off a shotgun blast. About a year ago it suddenly quit doing that, and I miss it.
Old 05-27-2013, 09:17 PM   #13
31 A4door
Tom is correct in my opinion. Sounds like hot plug or carbon causing the problem. Have you ever had the head off to see how much carbon buildup is in there?
31 A4door is offline   Reply With Quote
Old 05-27-2013, 10:59 PM   #14
jerry of whidbey
jerry of whidbey's Avatar
un burened gas in the manifold running to rich
jerry of whidbey is offline   Reply With Quote
Old 05-27-2013, 11:44 PM   #15
SeaSlugs
SeaSlugs's Avatar
oh yea my B&S rider would do that like clockwork if i killed it at anything other than low idle. I got used to lowering the idle all the way down then let it idle slow for about 10-15 sec then shut the key off. Gives the engine some time to cool down.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-28-2013, 08:05 AM   #16
OL JENNY
OL JENNY's Avatar
I had the problem, and if I did not run the gas out it would have the loudest backfire you could imagine. This was very bad if you pulled in to get gas. I finally found a small crack in the exhaust manifold that apparently provided enough heat on the carb that gas fumes would ignite after shutting the engine off. New manifold resulted in solution.
OL JENNY is offline   Reply With Quote
Old 05-28-2013, 11:14 AM   #17
Purdy Swoft
Purdy Swoft's Avatar
Mitch makes a good point in post 5. Its not the gas in the carb that does it, Its letting the engine idle slowly for the length of time that it takes for the gas to be used up that is in the carb and fuel line. Actually, you must have a leak at the exhaust manifold connections or a cracked manifold that allows air to enter the muffler for the backfire to happen. Weak ignition that doesn't burn up all the fuel is a big contributor. Fuel that isn't burned in the combustion chamber collects in the muffler. When the engine is cut off and the flow through exhaust stops, the muffler gets hotter. Air is necessary for ignition and explosion, this is where a leak between the manifold and block or at the exhaust pipe to the manifold comes into play. Running the GAV too far open or a carb running too rich or weak ignition will cause gas to collect in the muffler. Its a pain and embarrasment but it has happened to most of us at one time or another. just my thoughts.
Old 05-28-2013, 01:49 PM   #18
Rock Hornbuckle
Yes Ray, my key functions.
I should've mentioned that I let the clutch out slowly as I turn off the ignition. I stop the rotation of the engine so it will not continue to suck in gas and pass it out into the hot exhaust causing a backfire.
As a teenager in my '50 Ford business coupe, I would cause backfires while driving, by turning off the key, pressing on the gas pedal, then turning the key back on. It great fun to do it in front of the High School. lol
I know, it's a great way to blow a piston or blow out a muffler. Been there! But it was such fun being a teenager.
Semper Fidelis
