Old 08-19-2013, 11:10 AM   #21
Clem Clement
Clem Clement's Avatar
Default Re: Model A motor froze-up
Karl used to post on this site and had a great story about starting a stuck engine. he made a spark plug into a grease fitting and pumped the cylinder on the down stroke with grease. He kept pumping until the jug popped loose. He then fired up the engine is his garage! He said everything was covered with burnt grease!
Old 08-19-2013, 03:36 PM   #22
BetsyModelA
I found Kroil locally. I'll give it a try today.
Aww, patience, someone said. I'll let it soak a day or two before rocking it.
BetsyModelA is offline   Reply With Quote
Old 08-19-2013, 07:56 PM   #23
BetsyModelA
Ha! The guy at the NAPA store fibbed. He didn't have the Kroil. I did manage to get the MMO Marvel Miracle Oil from him though. I took the spark plugs out, poured about a cup of MMO into each spark plug hole, put Betsy into high gear, and then my husband and I rocked the pick up back and forth. Heard sloshing somewhere. Not sure if it was in the motor or if it was old gas. Will try the crank in a few days and perhaps more rocking. I'm thinking about emptying the radiator, putting clean water through for a flush. Will want to put water back in, but need a coolant. What should I mix with the water? Antifreeze or alcohol? I sound like a kindergarten kid, but I have to start at the beginning. Thanks for your help.
Old 08-19-2013, 07:58 PM   #24
Reds34
I wouldn't worry about the radiator yet. Concentrate on getting the engine turning over with some compression and then go from there. Just my $0.02.
Red
Reds34 is offline   Reply With Quote
Old 08-19-2013, 08:17 PM   #25
Terry, NJ
Terry, NJ's Avatar
Wow! I think half a cup would have been plenty! It's OK though, Just try to catch it when it runs out of the spark plug holes. If there water/Antifreeze in the engine thats good, No leaks! Let's concentrate on the engine first. Cooling system can come later. While you're soaking the engine, better drain all the old gas and flush the tank. There may be rust particles. Pour a little fresh gas directly through the tank. Maybe half a gallon or so to flush all the crud out. Reassemble the system and take the fuel line off and make sure it's clear. before you put the gas line on the carburetor, put a little gas in the tank and open the valve and see if it runs through. Keep rocking it in 3rd gear all the while.
Terry
Old 08-19-2013, 09:02 PM   #26
eagle
eagle's Avatar
Be careful doing this, you'll bust an engine up real quick. The hydraulic pressure out of a grease gun is very very high.
Old 08-19-2013, 10:30 PM   #27
dlshady
dlshady's Avatar
Originally Posted by Steve Plucker View Post
I understand that "Kroil" is 1/2 acetone and 1/2 ATF (Automatic Transmission Fluid)...Is that correct?
Pluck
I don't know what chemicals are in Kroil, but I can vouch for the fact that acetone and ATF works better than anything I've ever tried. Not too long ago I bought an old Warford overdrive for our Model T speedster project and it must have sat full of water for 70 years because it was completely rusted solid. I filled it with a 50/50 mix of acetone and ATF, and 30 minutes later I was turning it by hand. No joke!
Before:
Soaking:
My latest build thread:
http://fordbarn.com/forum/showthread.php?t=67881
dlshady is offline   Reply With Quote
Old 08-20-2013, 02:36 AM   #28
Dodge
Pull off the valve cover and make sure the valves are opening and closing useing a screw driver or something like it to check them. For some reason Model A's stick valves
when they sit. They can lock up a motor just like the pistons can.
Just make sure they are free before you try to unstick the rest of the motor.
I have seen a couple of blocks where they tried to tow the car to unstick the motor
and broke the lifter bosses right out of the motor.
So after the valves are unstuck check the lifters also.
And the ATF and Acentone thing really works, better than anything I've ever used.
Happy unsticking...........
Dodge
Dodge is offline   Reply With Quote
Old 08-20-2013, 08:06 AM   #29
BetsyModelA
Thank you, Dodge, for this helpful suggestion. I'll give this one a try for sure.
Old 08-20-2013, 08:07 AM   #30
BetsyModelA
This one gives me hope.
Old 08-20-2013, 06:05 PM   #31
Ross/Kzoo
Ross/Kzoo's Avatar
It wasn't mentioned but I hope that you didn't put the spark plugs back in.
Ross/Kzoo is offline   Reply With Quote
Old 08-23-2013, 03:47 PM   #32
BetsyModelA
Ross/Kzoo, Oops! Yes, I did.
Need to leave them removed?
With my lack of knowledge I need all information I can get to not back-step.
Old 08-23-2013, 04:10 PM   #33
dlshady
dlshady's Avatar
Just be sure and take them back out before you try and rotate the engine. You can't compress a liquid and if you try, bad things will happen.
Old 08-23-2013, 05:36 PM   #34
ba49
Once while watching Chasing Classic Cars, Roger the old mechanic let it slip that MMO was their "secret juice" they put in the cylinders to loosen engines that have been sitting for a long time. Seems to work for them.
ba49 is offline   Reply With Quote
Old 08-23-2013, 05:41 PM   #35
Ross/Kzoo
Ross/Kzoo's Avatar
Yes, leave them out until you get that motor spinning freely.
Old 08-23-2013, 06:54 PM   #36
BetsyModelA
I'm thinking I may have to go this route. The pouring Marvel's Miracle Oil and rocking isn't enough.
Old 08-23-2013, 06:56 PM   #37
BetsyModelA
I'm going to keep trying the MMO. But am also thinking of removing the head to take a look inside.
Old 08-23-2013, 06:57 PM   #38
BetsyModelA
Okay, Ross/Kzoo.
I put more MMO in. Will let it set 24 hours, and try again.
I bought a gallon. Have poured in 2 qts.
Old 08-23-2013, 07:03 PM   #39
Ross/Kzoo
Ross/Kzoo's Avatar
If you check the archive you'll see that many Barners will walk by their projects every couple of days and squirt some MMO or other products for weeks before trying to get it turning. Be patient but most of all try to get in touch with a Model A person or old time mechanic to help you with this. You seem to be in a remote area there. My niece lives in Dickinson and BIL and SIL in Baker Mt. so I get by there every so often.
Did you drain the crankcase? If so what did the fluids look like?
Old 08-23-2013, 07:26 PM   #40
Charlie Stephens
Remember too much force and you will be adding bent rods, a bent crank etc to your list of problems.
Charlie Stephens
