Old 03-19-2024, 02:41 PM   #1
arnhemmer
Default Timing gear cover
I have to repair the timing gear cover on my 1930 Tudor (plugging a hole).Is the metal cast iron or forged steel? This will help me to decide if I should TIG weld it or braze it.
arnhemmer is offline   Reply With Quote
Old 03-19-2024, 02:52 PM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Timing gear cover
The texture looks like cast iron to me.
Old 03-19-2024, 03:23 PM   #3
Joe K
Joe K's Avatar
It would be cast iron.
Welding/Brazing might make an issue with "warpage."
You might "flatten" it after the fact with sandpaper glued to a tablesaw table.
JB weld might be a better fix but you have to "grind" the surface to make a place for the epoxy to "grab hold."
Actually I've seen a perfectly good cover on Ebay for $8. I bought it because I saw it was actually a "Model B" cover which I wanted for use with a Gordon-Smith Air Compressor conversion - which uses a Model B centrifugal distributor to match the "load-no load" condition of a compressor engine. (cover/timing pin and Model B distributor have to be used as a pair to allow "normal" engine timing.)
Ebay: $14.88 plus ship best price currently.
To tell the differences between covers, see Vince Falter's page on the covers. The page doesn't seem available at this moment - perhaps Vince is working on the site?
www.fordgarage.com
Joe K
Shudda kept the horse.
Old 03-19-2024, 04:26 PM   #4
arnhemmer
That's what I was thinking. I'll try the JB weld first to see how that works out. Thanks for the reply.
Old 03-19-2024, 04:29 PM   #5
arnhemmer
www.fordgarage.com
Joe K
I'll be using JB weld. Thanks for the reply Joe
Old 03-19-2024, 04:58 PM   #6
Gene F
Gene F's Avatar
How did it crack...and there is a spring assembly that rides on that thing. Maybe you should try to find another one. Are you sure you want to try to fix that one?
Old 03-19-2024, 05:22 PM   #7
Joe K
Joe K's Avatar
The small differences between covers are shown at https://www.fordgarage.com/pages/timingcovers.htm
Joe K
Old 03-19-2024, 06:55 PM   #8
Charlie Stephens
I would think it would be easier to find another one. Temporarily thread the hole (maybe enlarge it) and put a bolt/plug in.
Charlie Stephens
Old 03-19-2024, 07:22 PM   #9
Joe K
Joe K's Avatar
Charlie Stephens
Or leave the threaded hole with a threaded "plug" - so the next generation can query their board "does anyone know why this threaded plug was used at this location?"
Joe K
Old 03-19-2024, 08:18 PM   #10
arnhemmer
Someone before me drilled and tapped the center of the cover and used a screw to keep the aluminum gear from knocking. It worked fine untill the thread stripped. One of the club members had a cover, so picked it up and I replaced the plunger spring and all is good. Thanks everyone for the replies.
Old 03-20-2024, 08:17 AM   #11
CT Jack
CT Jack's Avatar
Go get another cover. Don't waste your time welding, brazing, or yuck puckying with JB Weld. These are all band aids.
CT Jack is offline   Reply With Quote
Old 03-20-2024, 04:23 PM   #12
brito36
Just get another cover. they are plentiful and don't usually cost much. Save you some work.
brito36 is offline   Reply With Quote
