Old 09-29-2016, 07:11 PM   #1
thenuttyirishman
thenuttyirishman's Avatar
Default Okie joe 4'' Drop images
looking for pics of king pin in drop axle . On my stock 30 pick up the bearing takes the weight by being placed between the bottom of axle and spindle.
My 30 V8 coupe is running a Okie Joe drop axle. there isnt room between axle and spindle so they put the bearing on the top of spindle directly under king pin
is this right ?? Does any one have a different way ??
thenuttyirishman is offline   Reply With Quote
Old 09-29-2016, 07:13 PM   #2
skidmarks
skidmarks's Avatar
Default Re: Okie joe 4'' Drop images
Depends on the spindles you have
skidmarks is offline   Reply With Quote
Old 09-29-2016, 07:22 PM   #3
thenuttyirishman
I know it has 35 drums dont know if the had to change spindles to do it
Old 09-29-2016, 07:31 PM   #4
Brian
Brian's Avatar
35's have the thrust bearing on top as you describe
Old 09-29-2016, 07:32 PM   #5
JSeery
JSeery's Avatar
What year is the axle? Assuming a later year I would find some later spindles to match.
Axle A is a 28-31 Model A Ford which has been stretch dropped 4 inches.
Axle B is a 32 Ford Heavy which has been stretch dropped 5 inches.
Axle C is a 32-36 Ford which has been stretch dropped 4 inches.
Old 09-29-2016, 07:56 PM   #6
zzlegend
zzlegend's Avatar
Here is my Okie Joe dropped axle with stock model a spindles.
zzlegend is offline   Reply With Quote
Old 09-29-2016, 08:02 PM   #7
zzlegend
zzlegend's Avatar
Here is my Okie Joe dropped axle on my roadster with 39-41 spindles. Picture might be hard to see. The bearing is on the bottom of the axle. On the Model a pictured above, the bearing is on top. Not sure what you have for spindles. Hope this helps.
Old 09-29-2016, 08:18 PM   #8
skidmarks
skidmarks's Avatar
28 to 48 the kingpin boss is the same height and bore. Change the spindle to the later 37 to 41 or 42 to 48 if your running juice brakes.
Sometimes you can find a old ford axle with the kingpin boss cut down if it had chevy spindles and brakes installed at one point
Old 09-29-2016, 08:25 PM   #9
Jason in TX
Jason in TX's Avatar
Needle bearings below the axle and above the lower spindle mount
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 09-30-2016, 07:20 AM   #10
john in illinois
john in illinois's Avatar
37-41 king pin installation guide.
http://static.speedwaymotors.com/ima.../910-32121.pdf
John
john in illinois is offline   Reply With Quote
Old 09-30-2016, 07:45 AM   #11
scooder
Your "stock" 30 Model A isn't stock, if it was the beating would be on the top of the spindle directly under the brake operating thang. Not between the Axle and spindle.
I believe it was 1937 when the spindle was redesigned to put the bearing under the axle, can't remember what the 1936 had, hence my 1937 date.
Martin.
scooder is offline   Reply With Quote
Old 10-03-2016, 09:31 AM   #12
Mart
Mart's Avatar
That's right, Mart. The intro of the 37 "roundback" spindle also included the spindle below the axle, between the axle and the lower spindle boss. 36 spindles have the bearing on top like the earlier jobs.
Old 10-03-2016, 11:36 AM   #13
V8COOPMAN
V8COOPMAN's Avatar
Rule to keep in mind with old Fords..........The KINGPIN (and bearing), along with their assembly CONFIGURATION, is always determined by the year of the spindles used. DD
Click Links Below __
T5 W/TORQUE TUBE
