Old 08-16-2014, 09:57 AM   #1
CountrySquire55
CountrySquire55's Avatar
Default Front Wheel Wobble at Low Speed
Friend of mine has a 29 Fordor which has developed an occasional front wheel wobble when hitting bumps at low speed. Wobble is stopped by bringing the car to almost a complete stop. Does not happen with all bumps but more than 50%. I had the same problem last year with my 31 Slant Town Sedan and found my problem to be loose, worn pitman arm. Replaced pitman arm and my problem solved. Pitman arm is tight on friends 29 Fordor, as are lug nuts, wheel bearing, and (seemingly) all front end linkages, with very little play in king pins/bearing. Any suggestions on what might be causing this wobble problem? Thanks!
CountrySquire55 is offline   Reply With Quote
Old 08-16-2014, 10:34 AM   #2
Kevin Johns
Default Re: Front Wheel Wobble at Low Speed
I had this same problem with my 30 coupe. Front end seemed tight like yours, but the steering was loose. Took the coloum out and adjusted the 2 tooth worm and it totally eliminated the problem. His should have the 7 tooth worm gear and isn't adjustable, but some new guts should fix it. Or just don't drive slow!!
Kevin Johns is offline   Reply With Quote
Old 08-16-2014, 10:41 AM   #3
Chris in CT
Is the steering box tight to the frame? Put the car's front axle up on jackstands and wobble the front wheels back and forth while a buddy checks out the steering linkage.
The problem will reveal itself. Happy Motoring!
Chris in CT is offline   Reply With Quote
Old 08-16-2014, 11:06 AM   #4
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Saw this happen at the garage...Check the Nuts on the backing plates..make sure they are secure, this will cause a wobble and breaking problem.
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 08-16-2014, 11:54 AM   #5
Dick Carne
Dick Carne's Avatar
All of these are good recommendations - in short check all of the front end and steering-related connections. I experienced a similar occurrence several years back on our touring car and when I went to check the front spring perches, found that the spring perch on one side had broken in the axle and the bottom end was completely missing, Fortunately the weight of the car kept the spring perch from coming out of the axle, but nonetheless... I would advocate checking everything front-end related to make certain that everything is properly tightened. Good luck - its not as daunting as it might seem.
Dick Carne is offline   Reply With Quote
Old 08-16-2014, 12:17 PM   #6
Terry,NJ
Terry,NJ's Avatar
He has the feared "Death Wobble". There is no single cause. I had it in my coupe and replaced the left kingpin. I fixed it good for about a year. Then it came back. This time it was the spring bushings. I fixed them and it was ok for a while. Now it's back again. This time I'm going to rebuild the steering box. It's one of those things you have to chase.
Terry
Terry,NJ is offline   Reply With Quote
Old 08-16-2014, 12:37 PM   #7
Glen in Hillman MI
lots of good info above but don't forget to check the radius ball for wear and looseness
Glen in Hillman MI is offline   Reply With Quote
Old 08-16-2014, 02:00 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Remember that shimmy is almost ALWAYS caused by SLACK in the steering linkages and/or steering gear. The nuts that hold the steering arms to the spindles are OFTEN overlooked & it just takes a tiny bit of looseness to cause it to shimmy.
With weight on the wheels, have someone turn the steering wheel FIRMLY, back & forth & FEEL & LOOK at each part, including the radius rod ball.
Vermin had a shimmy, drag link & tie rod had all NEW parts & caps screwed in about flush, BUT, one of the drag link end springs was TOO SHORT!
Claude, our REAL GURU, is GOOD at spotting problems! He uses the Ford tractor safety inspection method, starting at the steering wheel nut & working down through the whole system, while having the shop GOPHER turn the steering back & forth FIRMLY
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-16-2014, 04:08 PM   #9
ford3
turn steering wheel stopped, the tires should move almost the same time as the wheel, no more than 1" of free play, also check wheel balance, a severly out of balance tire will cause wobble when hitting bumps or holes
ford3 is offline   Reply With Quote
Old 08-16-2014, 06:49 PM   #10
Fred K-OR
Fred K-OR's Avatar
Are your wheel bearings tight and lug nuts???
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-16-2014, 07:26 PM   #11
jmeckel
jmeckel's Avatar
If you had a rubber radius ball, (that is the ball that is under the transmission) check to make sure it has not fell apart, mine did, and the death wobble was no fun. Replaced the rubber ball with a new one, took longer to crawl under and out than to do the work. Problem solved. Someday I will put it back to original, but for now I like to just drive it.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 08-16-2014, 10:09 PM   #12
Brother Hesekiel
Brother Hesekiel's Avatar
Had exactly the same problem. Checked the entire front end and couldn't find anything worn. Installed a "cheap" SoCal Speed Shop steering dampener and the wobble is gone.
Brother Hesekiel is offline   Reply With Quote
Old 08-16-2014, 10:29 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
There are several threads on the subject here. May i suggest an advanced search in the Model A section?
Old 08-17-2014, 05:45 AM   #14
john charlton
john charlton's Avatar
Had the same problem turned out to be the front wheels were way out of balance . Cured by having them balanced at a tyre shop who glued on the weights on the inside of the rim The glued on weights are what are used on modern alloy wheels . 19" rims will accept the clip on style they cant be seen if installed on the inside . It surprising how far out the wheel balance can be .
John in cool cloudy Suffolk County England
john charlton is offline   Reply With Quote
Old 08-17-2014, 07:37 AM   #15
Terry,NJ
Terry,NJ's Avatar
John, I have an old bubble balancer that I do my wheels on and I"ve used the old style weights with good results. These are the old steel rim, weights.
Terry
Old 08-17-2014, 08:09 AM   #16
CountrySquire55
Thanks to everyone who responded! Lots of great suggestions here and in previous threads. Will pass on all this information to my friend and we will see what we find! Thanks again!
Old 08-17-2014, 10:41 AM   #17
Tom Foster
Ditto on the radius rod ball; I've had that problem on two A's. The steering dampener just masks the problem, though it will give some temporary relief.
Fearless
Tom Foster is offline   Reply With Quote
Old 08-17-2014, 02:08 PM   #18
BILL WILLIAMSON
Yo, my Bro,
Some folks consider the dampner as a "BAND-AID", NOT necessarily! If it works for you, USE IT.
Remember, some NEW vehicles come with them from the FACTORY!
Bill W.
Old 08-17-2014, 07:52 PM   #19
glenn in camino
glenn in camino's Avatar
If the backing plates were heavily painted when the car was restored, the paint behind the nuts has probably worn off leaving the nuts loose.
glenn in camino is offline   Reply With Quote
Old 08-17-2014, 10:54 PM   #20
BILL WILLIAMSON
GEEZ, Glenn,
Then Vermin's gonna' "fall" apart if I don't TOTALLY re-do ALL his bolts & nuts? I probably won't SLEEP tonite, wish I wuz a Dog, they jist go---ZZZZZZZZZZZZZZZZZZZZZZZZZ!
I'LL NEVER GET THROUGH I just want to drive him before I get OLD!
Mitch, please tell me Glenn's WRONG!
Po' Ol' Dad
