12-10-2022, 03:19 PM | #1 |
36 LB block any interest ?
Since I have been involved building and playing with V-8 Ford flatheads for a very long time there's two V-8 Ford engine blocks I rarely see. The first is the 1932 and second the 36 LB.
Recently I came across a very nice LB block all the machine work had been done but was never assembled. The cylinder bore is .040 new cam bearings have been installed. In those cam bearings is a NOS stock cam with matching NOS Ford fiber gear. Wondering if anyone would be interested in the LB ? Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
12-10-2022, 09:44 PM | #2 |
Re: 36 LB block any interest ?
I would be interested in the LB block. I've been debating getting a 59AB rebuilt for my '34.
Red |
12-11-2022, 07:16 PM | #3 |
Possibly. I need one for my 36 of almost 50 years. My block is in bad shape thanks to an incompetent machinist in it’s past.
12-11-2022, 10:33 PM | #4 |
What'e the big deal on an LB engine. Babbie bearings will last a heck of a lot longer than any of us will. Not worth the big bucks you're going to have to pay. My 2¢.
12-12-2022, 11:17 AM | #5 |
It's tough to find anyplace to get the babbit work done and also very expensive.
12-12-2022, 06:16 PM | #6 | |
I had a buddy that did it locally, but he has sadly joined the ranks of the dearly departed.
12-12-2022, 09:00 PM | #7 | |
No need for trying to find someone to do the Babbitt when you have the LB its rebuildable forever just put in the needed insert bearings.
12-12-2022, 10:25 PM | #8 |
So if I understand you correctly, the LB was the late version of that block type and would be equipped with insert bearings from it's start. That correct?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-12-2022, 10:47 PM | #9 | |
Yes that's correct insert main bearings.
12-12-2022, 11:21 PM | #10 |
LB stands for " large bearing"...if the rumors are correct !
12-13-2022, 05:47 PM | #11 |
Where is LB stamped on the engine, is it on the block under the intake manifold? I guess the only way to know for sure if you have babbit or inserts is to pull the pan!
12-13-2022, 06:07 PM | #12 |
The LB's I've seen are big letters, like 3/8 or bigger, on the front drivers side of the deck between the intake and head. Not all are stamped
12-13-2022, 07:08 PM | #13 |
The one thing to check on is the availability of insert bearings for the LB. I thought that I'd heard that they were getting quite difficult to find . . . buy maybe I'm imagining things! LOL
12-13-2022, 09:14 PM | #14 | |
Or Liner Bearing depending on who you ask.
They are the same as 37-38. Not thick on the ground by any means, but they can be found. The crank is the same as 37-38 also. |
12-13-2022, 10:16 PM | #15 |
Thars the location on the block I have and the few I have seen previously.
12-13-2022, 10:35 PM | #16 |
I wonder... Could the LB be machined to accept water pumps? I believe all else is like a '37? I know the '37/38 is the most versatile 21 stud, maybe include the LB with that mod?
Alan |
12-14-2022, 09:40 AM | #17 |
Not all LB blocks are stamped. I have a Insert bearing block with no stamping. It came out of a 35 1 1/2 ton truck. Dave/Green Bay
12-14-2022, 01:36 PM | #18 | |
The front of the block is different than the latter blocks so there's no material to machine on the front surface of the block to mounted water pumps. Ronnieroadster
12-14-2022, 11:27 PM | #19 |
Hi Ronnie,
I just saw this post. I'd be interested in this LB. and I'm here in Connecticut. Please let me know the details on it. Bruce/CT
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford |
