Old 03-31-2011, 10:40 PM   #1
crotex
Default new carb, Getting really cold on intake. Need advice
I have been having troubles with the Zenith carb on my 31 Model A and I ended up getting a Tillotson carb from a friend today. I got it on and now I have a crazy whistle noise coming from somewhere I can't fine and also the carb is getting so cold when running it has condensation dripping off of it as well as the intake. Please forgive me if this is dumb stuff to ask but I am new to this and I would like to get some advice on how to fix this problem. Another thing is that the motor will not stay running unless it is fully choked.
crotex is offline   Reply With Quote
Old 03-31-2011, 10:57 PM   #2
JC60B
JC60B's Avatar
Default Re: new carb, Getting really cold on intake. Need advice
Sounds like you have a vacume leak. Maybe base gasket
JC60B is offline   Reply With Quote
Old 04-01-2011, 02:18 AM   #3
1931 flamingo
1931 flamingo's Avatar
Vacuum leak.
Paul in CT
Old 04-01-2011, 02:57 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by crotex View Post
... I have a crazy whistle noise coming from somewhere I can't fine ...
Yep, sounds like a vacuum leak to me.
Old 04-01-2011, 02:58 AM   #5
crotex
what are all of the places I should check out? I chaged the base gasket with a new one and snugged the two bolts down pretty tight.
Old 04-01-2011, 03:25 AM   #6
Christoph
Christoph's Avatar
spray oil (fluid) to the gakets while engine is running
once sealing the leak, idle should change....
greetings christoph
Christoph is offline   Reply With Quote
Old 04-01-2011, 05:01 AM   #7
Pepsi Mechanic
Pepsi Mechanic's Avatar
If it is a used tillotson it could be in the carb itself . Should maybe rebuild it . Did you have the same problem with the zenith?... one thing for sure it is definatly a vacuum leak
Pepsi Mechanic is offline   Reply With Quote
Old 04-01-2011, 05:12 AM   #8
roccaas
roccaas's Avatar
Tilly's (and others) often leak where the throttle plate shaft pierces the updraft of the barrel. Mine whistled, had it rebuilt (Zenith and Tilly), no whistle, no updraft extra O2 to mess up the mixture. Vendors carry an inexpensive kit to seal the shaft, but MAKE SURE YOU DO IT RIGHT. I did it wrong twice and had the throttle stick wide open until I went to Neutral, under the hood, wrenched back the throttle horn.
Why is it cold and dripping? I'm stumped. Are you using freon for fuel? The Flux Capacitor? Leaking fuel all over the carb (bring a Fire bottle, a big one) and get that fixed.
Fuel bowl set too high can lead to gushes of fuel back through the intake. Full Choke in order to run is just your leaky Carbs way of saying she's getting far too much air for the stoichiometric fuel-to-oxidizer ratio to work it's natural charms.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 04-01-2011, 05:44 AM   #9
Mike V. Florida
Check the flange on the tilly that attaches to the manifold. The have been know to warp.
Now you will tell us what works this time won't you? Your solving of the electrical problem is still a mystery to us.
Old 04-01-2011, 05:55 AM   #10
James Rogers
James Rogers's Avatar
All the above is good advice but, here is the problem. The tilleys are made out of pot metal and as such are prone to the mounting flange warping. You have to have a light touch to tighten the nuts. A friend of mine used to, as a normal habit, tighten the carb before a tour. He couldn't figure out why his car would run so bad after a while. I used a file to flatten the flange and, took his 1/2" wrench away from him so, no more problem. Remove the carb, sand on a very flat surface or, use a large mill bastard file to flatten the top of the carb mount and the whistle will go away. Just be sure you don't tighten the nuts too tight and warp it again. The icing is also related to this problem since the carb is pulling cold air in above the rear intake, where the exhaust can provide warm air to prevent this.
You have to run full choke because you are getting too much air and have to choke it to pull enough fuel in to regulate the mix.
Hope this helps
Old 04-01-2011, 08:24 AM   #11
JBill
Be very careful mounting any carburetor to make sure it's mating to the manifold straight with no binding. It's easy to break an ear off your intake manifold. Does this sound like experience speaking??
JBill is offline   Reply With Quote
Old 04-01-2011, 08:54 AM   #12
Keith
I'll bet the top flange is slightly wrapped, Tilly's are famous for this. No matter how hard you try to seal they still leak air. The fix is to flatten out the top flange, It can be milled flat or place a piece of wet dry sand paper on a flat granite surface plate and sand flat in a figure eight rotation motion.
Keith
Keith is offline   Reply With Quote
Old 04-01-2011, 09:55 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
The icing is due to a pressure drop. The air flowing past the throttle plate goes under a large pressure drop, thus cooling the air. This icing is most noticable on cold damp days. My Alis Chalmers WD does the same thing until the engine is real warm.
My air compressor is outside and when I try to sandblast when the temp is about 35 to 40 degrees the cold damp air will often freeze in the line due to the pressure drop when I start using the blaster. Thus no sandblasting unless the temp is over 40*.
Old 04-01-2011, 02:25 PM   #14
Old182
Old182's Avatar
Tom is right (as usual). The pressure drop and resulting temperature drop is caused by the air flowing through the venturi just upstream of the throttle plate. Icing will form around the throttle on days when the ambient temp is just above freezing and the humidity is relatively high. Carburetted aircraft have carb heat systems where exhaust is routed to the carburetor to prevent (or to melt!) carb icing. My Farmall Cub used to do it but I fashioned a baffle in front of the carb to prevent cooling air from blowing over it.
Old182 is offline   Reply With Quote
Old 04-01-2011, 02:46 PM   #15
gerrald meacham
sounds like its running lean , when liquid vaporises it makes cool
gerrald meacham is offline   Reply With Quote
Old 04-01-2011, 04:48 PM   #16
1931 flamingo
Are you also leaking at either the exh or intake manifld where it attaches to the block??
paul in CT
Old 04-02-2011, 09:11 PM   #17
sphanna
sphanna's Avatar
You don't need an air leak to get carb. ice. Old 182 explained it exactly. Carb ice is caused by low pressure in venturi and will show itself mostly on humid and cool days. All pilots are very familiar with this. Happens to cars too.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 04-03-2011, 03:08 AM   #18
40 Deluxe
This icing/cooling effect is why most early cars had heat risers in the exhaust manifold, to direct the hot exhaust gas through passages in or next to the intake manifold. Later cars had tubes going from the air cleaner to tinwork around the exhaust manifold to run hot air through the carb when the engine was cold. Of course, the Denny-Dimwits would rip all this stuff off, thinking they were making their engine run better!
