03-17-2015, 11:53 AM | #1 |
Quick! What movie is it?
Who was driving and what were they driving?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
03-17-2015, 11:54 AM | #2 |
Re: Quick! What movie is it?
PeeWee Herman's Great Adventures
03-17-2015, 12:11 PM | #3 |
You driving Old Henry?????.....MARK
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
03-17-2015, 12:17 PM | #4 |
Clue: The greatest comedy of all time up until What About Bob.
03-17-2015, 12:22 PM | #5 |
Phil Silvers, '48 convert.
Ignorance of the laws of physics does not mean they do not apply to you. |
03-17-2015, 12:24 PM | #6 |
And the movie?
03-17-2015, 12:26 PM | #7 |
I don't think I'd ever have guessed Phil Silvers to be the greatest comedian of all time.
Alan |
03-17-2015, 12:27 PM | #8 |
OK, It's a Mad Mad Mad Mad World.
So what do I win? Let me guess, a chrome 59A pan with a large hole?
03-17-2015, 12:29 PM | #9 | |
03-17-2015, 12:38 PM | #10 |
Glory, honor, fame, and fortune.
(OK, maybe not the fortune.)
03-17-2015, 12:51 PM | #11 |
Agree one of if not the best comedy of all time. I still watch it and roll on the floor laughing
Thanks - 30-9 1939, 1940 |
03-17-2015, 01:16 PM | #12 |
So, quick, what fluid leaked on the ground?
(a) anti-freeze (b) oil (c) a & b Jack E/NJ |
03-17-2015, 01:27 PM | #13 |
Ah, now for "The Rest of the Story"
I had just removed my transmission to repair it then put it back in. I had just put the car on the ground, had pushed it out onto the driveway to clean up the garage, then was going to take it for a test drive. I started it up, backed out, and saw the oil pool and path. Pulled back in and shut it off. I had just filled the transmission and thought may I hadn't screwed the drain plug in good and the transmission oil was leaking out. I climbed under and tightened that but the oil hadn't come from there. It was engine oil that had come out in great quantity. I opened the hood and found the culprit. What had happened was, when I jacked the engine up to remove and replace the transmission, the plastic tube coming out of the brass fitting to my mechanical oil pressure gauge hit the gas pedal rod, bent, and cracked open. That's where all of the oil dumped out. Amazing how much came out so quickly through such a small opening - at least a quart or more.
03-17-2015, 01:47 PM | #14 |
Now we know that the oil pump is working...how's the trans working?
Gene |
03-17-2015, 01:49 PM | #15 |
Trans is good . . . so far.
03-17-2015, 02:52 PM | #16 |
>>>the plastic tube coming out of the brass fitting to my mechanical oil pressure gauge >>>
And what have we learned about using plastic tubing anywhere on a pressurized oil system even if it is tiny diameter? Jack E/NJ |
03-17-2015, 02:53 PM | #17 |
Watch out the EPA will send in the DRONES!
03-17-2015, 03:03 PM | #18 |
"I'm comin' Mama..." Hilarious movie, a true classic Hollywood comedy. They must have found anyone that didn't have any bookings at the time. |
03-17-2015, 03:10 PM | #19 | |
What I learned is to watch inside the engine compartment while the engine is coming up to see what's going to hit and be damaged.
03-17-2015, 03:24 PM | #20 |
Maybe so, but maybe less likely. I had one burst from the engine heat. Luckily it let loose as I was pulling into my driveway after a long run on a hot summer day. Stopped, got out of the car an immediately noticed the oil trail. Checked oil level --- down below the tip of the dip stick. Followed the oil trail to the end of the driveway where it stopped. Lost over 3 quarts in that short distance. No more plastic tubing in any of my hot engine compartments
Jack E/NJ |
