Old 03-26-2023, 01:18 AM   #1
1928 Sport Coupe
1928 Sport Coupe's Avatar
Default Brake improvement for Model A's
I have been reading the threads on brake improvement for Model A Ford's. I have not seen much about the Floater kits available from the vendors.
Are the floater kits of any help? If so are they worth the cost?
I saw on the thread about brake drums and Hydraulic conversion where nkaminar had talked about using the rear levers on the front. I thought about trying that. But still was thinking about the floaters. Does anyone have instructions on installing the floaters? I just do not understand how they work.
Is the floaters for just the front or are they for all four brakes?
Thanks in advance.
1928 Sport Coupe is offline   Reply With Quote
Old 03-26-2023, 05:06 AM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Brake improvement for Model A's
Have you looked here: http://flatheadted.com/
Old 03-26-2023, 06:19 AM   #3
jack wingard
the biggest improvement you can make is cast iron drums
jack wingard is offline   Reply With Quote
Old 03-26-2023, 09:13 AM   #4
TomInCologne
TomInCologne's Avatar
correct! i got my Margarethe from the Netherlands (no hills) and where i live we do have some hills, not the Alps but nethertheless. I threw out the old tine drums and swapped them against cast iron drums with new brake shoes, just the front, with brake equalizers. Totally different car. Now i can brake a second and third time going downhill whereas before the second trial always resulted in additional braking with the emergency brake.
Next winter i will also swap the rear drum brakes, but that's not a high priority. I don't need more capability in the brakes...
TomInCologne is offline   Reply With Quote
Old 03-26-2023, 09:32 AM   #5
Shiloh
Wow! Just came to the Barn to ask the same question! I look forward to the responses. I ordered some floater for the front brakes from Mikes last night because they were really affordable. But one thing a person should not skimp on is stopping power especially in todays traffic. I’ve been eyeing the flat head Teds.
Shiloh is offline   Reply With Quote
Old 03-26-2023, 11:02 AM   #6
Dick Carne
Dick Carne's Avatar
I am of the impression that you will find both good and bad reviews on Flat Head Ted's. I installed them on our Town Sedan several years back when re-doing the braking system, and I struggle now with the brakes locking up when I go to back up after having applied the brakes (I always have to go forward slightly in order to release them). I have a friend who has commented that he had had the same experiences, and removed that set-up and returned to the original linkages. I am considering doing the same on this car as well. By the way, just as an FYI when considering whether other factors might be involved, when we did the brakes on my car, I replaced all bushings, rollers, shafts, cast iron brake drums, etc. I have not been able to determine any significant difference between that car and our other Model A's that do not have the Flat Head Ted's set-ups. Good luck whatever direction you decide to go.
Dick Carne is offline   Reply With Quote
Old 03-26-2023, 11:27 AM   #7
1928 Sport Coupe
I will take a look at the web site. Thanks
Old 03-26-2023, 02:03 PM   #8
nkaminar
nkaminar's Avatar
The FHT floaters are worth it. Better stopping with less pedal pressure. But they have to be installed correctly and the brakes have to be in A1 shape to begin with.
Old 03-26-2023, 04:51 PM   #9
Synchro909
Synchro909's Avatar
IMO, the main problem with the brakes on the Model A is the strong bias towards the rear. To bring that nearer the correct (by today's standards) 60/40 towards the front, I have left things as they are at the back but put cast drums with riveted woven linings on the front along with that floating pin conversion. That improved things out of sight but in a moment's inspiration, I looked at the length of the front and rear actuating levers and immediately saw why there is the bias. My answer was to graft a pair of rear actuating levers onto the front. It took a bit of machining and fiddling but now, my brakes are about as good as is possible with such narrow tyres.
Old 03-26-2023, 05:36 PM   #10
eagle
eagle's Avatar
My A has original everything except drums. Stops very well, and all wheels lock up at about the same time. Not sure how that can be improved? Yes, every few years it needs a little adjustment, not a big job. My other old cars are hydraulic, its a constant struggle to get them working after sitting the winter. Maybe in a dry, temporate environment it'd be different but NOT here. As to the original posters questions, I'd say go with the new drums, fix your brakes to new specs, and drive it.
Old 03-26-2023, 07:26 PM   #11
nkaminar
nkaminar's Avatar
Maybe Eagle has his brakes adjusted to put more braking on the front. Backing off the rears one or two notches may do the trick.
Eagle: in your juice brakes, what fluid are you using. I understand DOT 5 does not pick up moisture, or is it synthetic brake fluid?
I put the longer levers on the front of my car after Synchro let his secrete out.
Old 03-26-2023, 08:42 PM   #12
mhsprecher
mhsprecher's Avatar
Wouldn't adjusting the brakes with more bias towards the front be another alternative, or adjusting the brakes so they all have the same amount of drag? The Ford shop bulletin and Les Andrews' approach is to start the rear brakes engaging first. Ideally, you don't want the fronts to lock up so that you maintain steering in the case of a panic stop.
My town sedan has cast iron drums and stops great. My roadster still has steel drums and stops okay given that I know their limitations, but I plan to install cast iron drums all the way around on it in the next couple of weeks. I know some people only install cast iron drums on the front, but it doesn't make much sense to me.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 03-26-2023, 09:31 PM   #13
Keith True
Keith True's Avatar
The bias is created by the linkage geometry,not adjustment.You can get to the more braking on the front by adjusting,but you are really just under-adjusting the rears.I've seen two instances where the Teds floaters were a problem,and one turned out to be worn adjuster housings.I didn't find the problem,another mechanic friend did.The other time I did find the problem.I adjusted the brakes as they were supposed to be done,and the problem went away.The owner had been using that board,and it is just too much of an arbitrary tool that makes no allowances for uneven wear.
Old 03-26-2023, 11:41 PM   #14
1928 Sport Coupe
I looked at Flathead Ted's website and tried to read about the different kits. I am still thinking on it.
Another question I have. Which lining is better the molded or the woven? I do not tour with the car, i just drive it for pleasure. Probably no more than 40 miles from home.
I think I will rebuild the brakes back to new stock condition plus the new cast drums. Of course that means new bushings, brake rods (mine have been bent to adjust in the past), and anything that is worn or broken and beyond repair. I may also try the rear levers on the front.
I want to have the best brakes I can without changing the mechanical brakes to Hydraulic. I want the car to look stock.
Thanks again.
Old 03-27-2023, 12:08 AM   #15
Synchro909
Synchro909's Avatar
Thanks again.
Woven!
Old 03-27-2023, 05:37 AM   #16
updraught
updraught's Avatar
https://youtu.be/lcJ5LUbmro0
https://youtu.be/2EjRe411l3M
You'll need to watch both.
You can get shoes from Randy that are matched to the drum.
I was told in my youth, linings needs to be soft. Use hard at your own peril.
updraught is offline   Reply With Quote
Old 03-27-2023, 06:57 AM   #17
BIG KEV
BIG KEV's Avatar
The real brake upgrade is the 1932 and up brakes. I swapped my fronts to the 32 brakes and the difference is hands down amazing.
The floaters do help either these or the stocks for sure... Also ditch stamped steel drums indefinitely.
BIG KEV is offline   Reply With Quote
Old 03-27-2023, 07:04 AM   #18
BIG KEV
BIG KEV's Avatar
Few pics of the upgrade...
Old 04-03-2023, 08:37 PM   #19
whirnot
whirnot's Avatar
Thanks again.
I have all three types of lining, The original style woven, the soft Molded and the soft Woven that I got from Berts.
The original work great but are too "grabby" and noisy. The soft molded work quite well. But in my experience the soft Woven work the best, even though I have them on the heaviest car.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-04-2023, 10:38 AM   #20
cas3
I'm with Big Kev, I put 35 brakes on front of my coupe this winter...What a difference !
