03-08-2013, 09:38 AM | #1 |
All righty then !!!!
So what's up next ??????
03-08-2013, 09:44 AM | #2 |
Re: All righty then !!!!
This weekend I will try to get the following tasks completed: Re wire tail light buckets; Change oil; drain coolant and replace four hoses; lube chassis and suspension. In the next few weeks: install reconditoned aluminum intake, new fuel pump and Stromberg 97 Carburetor. Will be 50 degrees F on Sunday. TM
03-08-2013, 10:17 AM | #3 |
Hang up the shovel for now and install new sump pump.
Still smokin tires and cigars |
03-08-2013, 10:31 AM | #4 |
Getting engine back together and finally install heater. Just in time for warm weather. lol
03-08-2013, 10:31 AM | #5 |
Get well from a bad case of the flu . Get several part purchases boxed and shipped to fellow Fordbarner's. Get to work on my '35 fordor for the cross country tour to Lake Tahoe. These are my priority's right now
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 03-08-2013 at 01:06 PM. |
03-08-2013, 10:41 AM | #6 |
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
03-08-2013, 12:05 PM | #7 |
After I go blow the snow off the driveway..Take off the electric pump and put the mech. set up back to original..All the parts came yesterday...I may still leave a elec. pump ,but I'll make sure it's a "quiet one" and will flow through...Then put a switch under the dash for it if I need it....The guy I got the car from Attacked the "Non Vented Gas Cap Problem" with a giant,noisy,electic pump....Then set the reg to 1/2 lbs...I still don't know why it didn't suck the tank into a "Crushed Beer Can " ...
Whether you think that you can,or that you can't,you are usually right....H.Ford |
03-08-2013, 12:10 PM | #8 |
Picking up some F-1 brakes today....gonna clean, paint, replace internals, and set them up on my '39 spindles. I'm also planning on getting back to that window issue I posted about a few weeks ago. I put it aside to work on some other things...hoped it would fix itself, but no dice.
03-08-2013, 12:24 PM | #9 |
Just finished clearing more snow. Now it's time to check and prep the Courier for the trek to the Florida Bash. So what's up with you, Bill?
03-08-2013, 12:37 PM | #10 |
a buddy was here today, 60 degree weather and pestered me to get the 41 fire engine up and running, maybe after plowing the garden, running the tiller thru it several times, putting down lime, mulch, till again---on second thought the truck is calling me--bye for now!!
03-08-2013, 03:06 PM | #11 |
Get my shocks back from Bill, install them on the "A", then go for a cruise!
03-08-2013, 08:45 PM | #12 |
Finish polishing the roof and dash, running all the rear brake lines, order parts and sit by the fire ripping into the speedometer head.
03-08-2013, 09:52 PM | #13 |
Going to work on the car tomorrow. Get the horn rod back in, hook up the rest of the wire harness for the coil, starter part. Yank the rest of the lights harness out. Replace radiator hoses. Then I am going to pull the headlight buckets so I can work on them at home. Oh and pull the fuel gauge to look into redoing it and pull the brake handle to get replated....swap rear bumper for nicer one I picked up.
03-08-2013, 10:03 PM | #14 |
Bill W & Ford guys:
Started 32 Rdstr just fine after it sitting too long! Hot wire / started 32 2dr on gas jug---next line fuel tank & reinstall ,then replace wiring. Go to Norman,OK swap Mar/14,15,16--if SS check holds out--Go SOONERS! Then to 40s in barn. Hoping my buds and me can get Van Norman V grinder to turn out reground orig valves for several flathds prewar 221,239s, 59,255. Money doesn't cover all them, so we try to step out & up with our work. That's up next. Ain't this fun! We're lucky guys all!! Gene, Toby and gang Tulsa,OK |
03-09-2013, 09:58 AM | #15 |
In the process of putting rear disc brakes on my 55 F-100
03-11-2013, 08:17 PM | #16 |
Finish installing the newly rebuilt door locking assemblies, both sides.. Clean up the two 17.5 rims and paint to replace two old widowmakers...
03-11-2013, 08:23 PM | #17 |
Get ready for the "Barner's Bash" from March 22nd to 24th.
03-11-2013, 08:54 PM | #18 |
Put new rings in the 36 woodie, new dash cover and dash pads for the 63 corvette convertible, finish up the last 5% of a 29 roadster restoration, pull the mitchell OD from the 28 open cab pickup. Seems I've been a car mechanic since retiring 3 years ago.
03-30-2013, 07:45 AM | #19 |
Going to install the tail light cross over harness and the body harness and maybe new stoplight switch--rewire all the way to the dash harness junction (will finish dash rewire once the new intake set up is installed). Install Fuel guage wire too. Re install fuel tank because the fuel filler neck is not lining up correct. And if time permits, install rear axle frame bumpers. Gonna be 58F today. TM
03-30-2013, 08:15 AM | #20 |
Just got L-100 cam back from Fl. going to start assembling 276 for a friend with a shoe box. No rest for the wicked. Walt
