07-29-2016, 06:08 AM | #1 |
Sad, sad sad
07-29-2016, 06:31 AM | #2 |
Re: Sad, sad sad
Tragic. Hopefully the tires were not old ones. Something we need to be careful about.
07-29-2016, 07:34 AM | #3 |
Re: Sad, sad sad
Sounds like another "subframe" failed.
07-29-2016, 07:40 AM | #4 |
Re: Sad, sad sad
JimTN
You are just speculating. You should wait until you know the facts. Tragic,sorry for the familys loss |
07-29-2016, 07:40 AM | #5 |
Re: Sad, sad sad
I saw no mention of a subframe. Says it was a failed tire on the rear. A sad accident that happens way too often. That it ends with three lives lost is horrible.
07-29-2016, 07:40 AM | #6 |
Re: Sad, sad sad
07-29-2016, 08:25 AM | #7 |
Re: Sad, sad sad
This was a Street Rod with modern upgrades. There was some type of tire/wheel failure that resulted in loss of control and impact with another vehicle.
07-29-2016, 08:43 AM | #8 |
Re: Sad, sad sad
Wow, who makes up this shit, "subframe" failed? Three people out having a good time. Sad.
07-29-2016, 12:12 PM | #9 |
Re: Sad, sad sad
I would really like to know more about the tires & wheels. Type, make, age, etc? And, what really failed?
This is so sad |
07-29-2016, 12:48 PM | #10 |
Re: Sad, sad sad
The answer might be as simple as a blowout due to a road hazard cut or defective tire.
However the stock fender wells don't allow a very wide tire which are favored by street rodders. Had several 46 and 48s..... |
07-29-2016, 02:19 PM | #11 |
Re: Sad, sad sad
I hate to hear about this stuff for both the loss of the old vehicle and especially the loss of folks that are basically just like the rest of us. The fact is that tires & wheels can fail and even on late model vehicles. I've had more than a few wheel/tire related failures in my time and have been fortunate that there was no catastrophic accident like this one. Keep a close eye on your wheels & tires folks.
07-29-2016, 07:23 PM | #12 |
Re: Sad, sad sad
If it is as reported to date, namely a sudden blowout of a rear tire, that is often a recipe for disaster, old car or new, if the driver makes the mistake to hitting the brakes at high speed. The road where this took place suggests the speed traveled was likely between 65 and 75 mph.
07-29-2016, 08:59 PM | #13 |
Re: Sad, sad sad
Blowouts on the rear will cause sudden loss of steering control, far worse than a front blowout at speed. Few drivers get much experience dealing with tires that suddenly fail since the introduction of tubeless tires. Something to think about when considering running tubes in radials?
07-30-2016, 08:00 AM | #14 |
Re: Sad, sad sad
We also have to think about the age of the tires on our cars. Just because they look good don't mean that they are.
07-30-2016, 08:37 AM | #15 |
Re: Sad, sad sad
This is very tragic and could happen to any of us in any vehicle.
This makes me think back to the Ford/Firestone recall on the Explorers. In one of my DD cars I had a slow leak in one of my tires (fairly new). I procrastinated going to the tire store for a proper repair and instead drove with a low tire plenty of times and just aired it back up once a week. Finally I took the tire in for repair (valve stem leak) the tire was ruined. In between the treads it looked dry rotted with cracks all over it. The repairman explain it was from driving with too low of pressure and needed replaced. I'm lucky it didn't blow. The cracks don't show when the pressure is low unless you distort the tread. Fully air up it looked the desert floor. I pay closer attention to the tread and look for cracks more often.
Thank God this is only a hobby! |
07-30-2016, 03:32 PM | #16 |
Re: Sad, sad sad
Murphy tells us about things going wrong. I'll share a for instance. I had a tire going flat on a 39 coupe. So I take a new tube to Town Fair Tire and have it installed. All is good. On the way home from a local show a friend of mine driving the car had to ditch the car ASAP , the rear tire had gone flat. Thankfully at 30 mph. Had it happened at high speed... And here's the cause- The tire tec guy left a plastic tie in the tire or it flew in from the shop before it was remounted. Unbelievable. Everyone here is jumping in with their stories, and it is how we learn. But leave the detective work to those who have the clues.
07-30-2016, 03:37 PM | #17 |
Re: Sad, sad sad
This happened to me years ago when having a set of Garfield tires mounted with tubes on '46 Ford rims. Somehow one of those shipping tags with the wire that goes through a red grommet, ended up between tire and tube and rubbed through tube.
"Never complain,never explain"... Henry Ford II |
07-30-2016, 03:49 PM | #18 | |
Re: Sad, sad sad
