02-07-2022, 05:49 AM | #1 |
Spark Plug Wire Holders
I plan to use the original spark plug wire holders on the 8BA I am building.
The engine I salvaged them from had all of the Left hand side (5-8) wires routed through both holders and all of the Right hand side loose. Does anyone have any pictures of the original layout ? |
02-07-2022, 08:06 AM | #2 |
Re: Spark Plug Wire Holders
Look through this thread and you will find and 8BA with a spark plug wire holders similar to yours. Even though the holders are a different style at their top, I think the routing is still the same.
https://www.jalopyjournal.com/forum/...dster.1194785/ Last edited by 19Fordy; 02-07-2022 at 11:07 AM. |
02-07-2022, 01:56 PM | #3 | |
02-07-2022, 02:23 PM | #4 |
There are directions and a "photo" on page 57 of the 49-51 shop manual.
Good luck. Russ Brown |
02-07-2022, 04:23 PM | #5 |
Thanks for the replies. Unfortunately I don't have a factory Manual.
Those pictures on that link 19Fordy do give a good indication of how they routed the wires. That basically reflects what I observed on the old engine I salvaged these from. These holders when removed were bent at odd angles as in the pictures although not so easy to discern. A side on shot would illustrate this better . I wonder if they have become bent over time? Those pictures would suggest that they should be straight up and down. |
02-07-2022, 04:28 PM | #6 |
02-08-2022, 08:59 AM | #7 |
While doing research on the 49-51 Mercury at the Benson Ford Research center a while back, I came across this drawing of the 0BA-12290 Ign. Cable and bracket assembly. I hope that this helps.
02-08-2022, 10:09 AM | #8 |
Wow, Don, Thanks for posting that drawing.
02-08-2022, 03:48 PM | #9 |
Don, thanks for that illustration. Great find. Well done.
02-08-2022, 04:31 PM | #10 |
After some trial and error and some straightening of these brackets this is the arrangement I have come up with. Seems to achieve what is set out in the drawing.
