Old 05-18-2012, 07:45 AM   #1
JJOHN
Default Best engine replacement for a 1935
Now that my garage has been cleaned out and there is plenty of room, I would like to pick up a spare engine to rebuild for later use in my 1935 Ford sedan. I would like to get one that is somewhat easy to install or what is the best replacement without any major trouble. Wife won't be happy when she reads this.
JJOHN is offline   Reply With Quote
Old 05-18-2012, 08:29 AM   #2
1928jalopy
Default Re: Best engine replacement for a 1935
JJohn
Look under my post....lost of information on which engine would fit best
"Installing a Y-Block in a 36 Coupe"
1928jalopy is offline   Reply With Quote
Old 05-18-2012, 08:35 AM   #3
Seth Swoboda
Seth Swoboda's Avatar
JJohn,
I guess it depends if you are going for originality or not. If you are going for originality go with the early 21 stud engine. If not, then find a 59A engine or any of the later flatheads with insert bearings. Any of the flathead V8's will go into your '35 sedan.
Seth Swoboda is offline   Reply With Quote
Old 05-18-2012, 09:14 AM   #4
richard crow
37 21 stud ez install cheaper than rebab 35 or 36 lb use block off plates & heads with water pump in them. hard to tell the differance. when done onley proulbem 37 eng hard to find but if you got time its worth the hunt. good luck.
richard crow is offline   Reply With Quote
Old 05-18-2012, 09:38 AM   #5
blucar
blucar's Avatar
The main question to keep in mind is, just what is your intentions for the car? If you want to keep the car basicly stock, the 21 stud engine fills that bill... A late '36 or '37 with the insert bearing would be the most desirable.
If you want to improve things a little move up to '42-48 engine, preferably the '46-48 59AB engines... Using your '35 exhaust manifolds and some slight modifications to the coolant plumbing will give you an increase in horse power with a moderate price.
If your intentions are to just build a car/engine to putt around town stay with the '36 LB engine.. These engines also have hardened valve seats which cut down the cost of rebuilding.. Of course the majority of the 24 stud engine have hardened valve seats, with the exception of many of the 8BA/8CM '49-53 engines.
Bill.... 36 5 win cpe
Old 05-18-2012, 09:59 AM   #6
ford38v8
ford38v8's Avatar
I agree with Richard. '37-'38 21 stud, using '36 cast iron heads, your '35 intake manifold, and '37 water pump block off plates. Much easier to find than an LB block, and virtually no modifications required. Best block would be a 59 series ('46-'48), but much harder to find.
Alan
Old 05-18-2012, 01:29 PM   #7
[email protected]
The '46 engine in our '38 is a great motor. I like the crab style distributor with a coil. I think the greatest improvement we made was a rebuilt 12 generator (we used the case on the original generator for mounting purposes) and voltage regulator. It doesn't appear too much different than a '38 engine. Both are 24 stud engines. If you don't need to be "judge correct" it's my suggestion.
It's 110 miles to Chicago
We've got half a pack of cigarettes
It's dark
And we're wearing sunglasses
Let's go.
garrisonm89@yahoo.com is offline   Reply With Quote
Old 05-18-2012, 02:16 PM   #8
JJOHN
Thanks for the info...original is not a concern as I don't care to be "judge correct" I would rather just drive it and enjoy it along with the family. Thanks again for the helpful information guys.
Old 05-18-2012, 03:26 PM   #9
Charlie Stephens
You might also ask your insurance agent what they like. The company I had wouldn't take you if your engine was more than 2 years newer than the car. I don't know what the market is like today for insurance.
Charlie Stephens
Old 05-18-2012, 06:00 PM   #10
[email protected]
Charlie Stephens
Hagerty. If you want to insure it for more than what a regular '35 is worth get a good inspection of the vehicle with an appraisal and send it to them. Otherwise just purchase their insurance. They might limit your mileage but it's usually within a reasonable amount.
It's dark
Let's go.
Old 05-18-2012, 06:21 PM   #11
funrunr
funrunr's Avatar
I know I'm kinda far away but I still have 2 flatheads for cheap money. Here is a post on here from a while ago that I haven't bumped. Check em out, desirable engines.
Either way good luck.
https://www.fordbarn.com/forum/showthread.php?t=46587
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
