07-06-2012, 11:21 AM | #1 |
Replaceing a Fan Belt on '35
Had to replace the fan belt on the '35. Ordered and received a 40-8620 belt. Having a bear of a time getting the belt on. It seems a bit tight--any ideas or similiar problems with this belt and its installation?
07-06-2012, 11:29 AM | #2 |
Re: Replaceing a Fan Belt on '35
Do you have the correct intake on that engine?In 37 the intake gen mount is a bit higher.
07-06-2012, 01:47 PM | #3 |
I ran into the same problem (on a 36 engine). I couldn't make the belt sold by one of the vendors fit. I very well might have a later intake, as DL suggests. In any event, I ordered another belt at my local parts store, based on the length needed. In my case, a Dayco 5L570 works well. (I think this is 57.0-in, and the previous belt that I couldn't install, is 55.5-in.)
Also note... I've never been able to install the belt, simply slipping it on. I've always had to remove the fan, un-do the gen from the intake, and tip the gen forward, to get the belt on. |
07-06-2012, 02:29 PM | #4 |
Here is a pic that I posted on an intake question. This shows the difference between the two intakes. Ed
07-06-2012, 02:41 PM | #5 |
Of course your vendor will tell you that you are the first one to complain about the fit...!
If you measure that "1935/1936 Ford Belt" that the vendors sell you will find it's too short. Get a Gates B-54 and you will be a happy camper. |
07-06-2012, 03:11 PM | #6 |
07-06-2012, 11:48 PM | #7 |
I have a stock '49 F1. The 53" water pump/generator belt I tried to use from Macs, is labelled 53", but is shorter and won't fit. Macs 55" belt, part# 40-8620-S, is actually 53" and fits perfectly - a friend bought it for his 36 and it is too small. My fan belt needs to be 34" and, again Macs belt, part# 21A-8577-S labelled as 36", is two inches shorter and does the job. Packaging on both belts says 'Made in USA'. ???
07-07-2012, 06:20 AM | #8 |
I also have had the same problem using a USA made belt. Turns out that Bobh has it right, wether you have an early 35 or late 35 manifold - yes they are different, you have to tilt the gen/fan assembly to get it on.
I have tried both manifolds with same belt and similar result. Daveh |
07-07-2012, 06:35 AM | #9 |
Also make sure the generator pulley is correct 4.38" Dia.
07-07-2012, 06:39 AM | #10 | |
07-07-2012, 02:26 PM | #11 |
My 40--- says Made in Korea. I don't know who sold it as it was on the car.
[FONT=Comic Sans MS] |
07-07-2012, 03:37 PM | #12 |
2x the NAPA B54 belt.
Don't try to shoehorn the one you got with he Ford part number onto the car it will be way too tight. |
