04-07-2012, 02:44 PM | #1 |
Rear shock removal 1935 Ford
Having a problem removing the rear shock of my 1935 Ford. I Got the two bolts that go thru the frame out, removed the shock arm clamping bolt but am now having trouble getting the arm off. I don't want to snap the arm-any tricks to the trade on this removal?
04-07-2012, 03:12 PM | #2 |
Re: Rear shock removal 1935 Ford
Try spreading the slot that closes up with the clamping bolt. After removing that bolt, drive a wedge [screwdriver etc] into the slot and that should loosen the arm on the square, allowing you to simply pull it off.
04-07-2012, 03:42 PM | #3 |
www.fordcollector.com |
