01-29-2012, 03:48 PM | #1 |
pickup wood
whats the best wood to use in the bed of a 36 pickup. for visual purpose only, it will never haul anything.
01-29-2012, 03:58 PM | #2 |
Re: pickup wood
White oak or Ash. Quartersawn if you can find it. Be sure to leave space for expansion/contraction.
John |
01-29-2012, 04:29 PM | #3 |
Re: pickup wood
If there is a sawmill near you, check to see if they have black walnut or cherry. Both look beautiful in the bed,depending upon the color of the truck.
Matt 24:36-41 |
01-29-2012, 05:41 PM | #4 |
Re: pickup wood
Bruce Horkey has an amazing variety of both common and rare woods for pickup beds. They are great to do business with.
01-29-2012, 07:01 PM | #5 |
Re: pickup wood
I was lucky enough to find some "reclaimed" black walnut for my 37 pickup. The price wasn't too bad. It was down right beautiful. Wish I had pics downloaded. There are places that sell wood that have been saved from old buildings,barns,floors,and furniture. It's well worth the time to check in your area,and see what you can find.
When will I be old enough to know better? |
01-29-2012, 07:41 PM | #6 |
Re: pickup wood
01-29-2012, 08:11 PM | #7 |
Re: pickup wood
I prefer the steel bed as original. Wood sub floor.
01-29-2012, 08:44 PM | #8 |
Re: pickup wood
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
01-29-2012, 09:03 PM | #9 |
Re: pickup wood
I'm using the original steel bed and staining the shellacking the wood that shows from the bottom.
01-29-2012, 09:38 PM | #10 |
Re: pickup wood
check with your local cabinet shop,they usually have many species of wood in stock.
01-29-2012, 09:39 PM | #11 |
Re: pickup wood
Cedar looks pretty nice JMO. ~~Walts37~~
01-29-2012, 10:14 PM | #12 |
Re: pickup wood
01-29-2012, 10:42 PM | #13 |
Re: pickup wood
Used red oak for mine. Has stood up real well for 15 years.
Butch |
01-29-2012, 11:57 PM | #14 |
Re: pickup wood
I used Apiton with a coat of hand rubbed Tung oil on my 40 Tonner. We use it on our equipment trailers - its bullet proof and looks good.
01-29-2012, 11:57 PM | #15 |
Re: pickup wood
Butch, What did you use as a finish on your red oak, that is what I'm using in my 48..I have seen a lot of finishes flake such as urithane and marine varnish, I was watching a Chip Foosh show and he said he never uses anything but linseed oil, just retreat about once a year..what do you think.. Ernie
01-30-2012, 01:17 AM | #16 | |
Re: pickup wood
01-30-2012, 11:39 AM | #17 |
Re: pickup wood
Most lumber yards have a place where thay put their used plywood thai is broken or stained. This makes a great floor for a pickup. I did one in Black cherry amd it was no longer a pick up, but a beautiful piece of furniture.
01-30-2012, 12:25 PM | #18 |
Re: pickup wood
1/4 sawn red oak is beautiful....mahoganey will also last a lifetime. i had a front prorch made with a brazilain hard wood called ippay (not sure how you spell it) but this stuff is hard as nails and will never rot in our lifetimes.
01-30-2012, 01:06 PM | #19 |
Re: pickup wood
" I've found Tung or Teak oil to be better for preserving wood exposed to the elements. I recoat the bed of my truck annually with Tung oil - a simple process of wiping on a light coat of oil, let dry for 1/2 hour and wipe off the excess."
And make sure you get TUNG oil and not Tung oil finish. Two different items!! I had to go to www.woodcraft.com to find a source and you need some marbles to fill the void as you use it or it goes bad. Follow the directions! |
01-30-2012, 01:30 PM | #20 |
Re: pickup wood
I got my hardwood for my last pickup @ Lowe's - not original looking but it did look good and it was fairly inexpensive. Check out the pic ....
Another possibility is cabinet grade plywood - seal the ends real well and varnish top and bottom, it will be good for years and one 4x8 sheet will do ya. |
