Old 11-26-2013, 10:03 PM   #1
David31dlxslant
David31dlxslant's Avatar
Default Early flip top jack
Hey guys new guy here. Been in the model a hobby for 8 years now. I recently bought a flip top jack and after receiving it I realized it said on the side it was made by Ajax but according to the judging standards it says that walker made those jacks, does anyone have any insight on these jacks? Here is a picture of the one I boughtimage.jpg
David31dlxslant is offline   Reply With Quote
Old 11-26-2013, 10:40 PM   #2
160B
160B's Avatar
Default Re: Early flip top jack
try this link to the MAFCA website for tools jacks
http://www.mafca.com/tqa_jacks.html
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 11-27-2013, 10:10 AM   #3
David31dlxslant
Yea I've looked at those jacks on the MAFCA page and it basically says the same thing that the judging standards say but I've heard it's not always correct. Just wondered since mine is made by Ajax if its still a model a jack?
Old 11-27-2013, 10:11 AM   #4
David31dlxslant
Also how do I post a picture of my car on the left side like y'all do when you post stuff, it's like a photo signature or something?
Old 11-27-2013, 10:28 AM   #5
WTSHNN
WTSHNN's Avatar
Go to "USER CP" near the top left of this page. On the left you'll see "Edit Avatar"
There you go.
-Tim
WTSHNN is offline   Reply With Quote
Old 11-27-2013, 01:04 PM   #6
David31dlxslant
Cool thanks Tim
Old 11-27-2013, 01:35 PM   #7
Fred K-OR
Fred K-OR's Avatar
Have a simple question about these types of jacks. I think I have a couple of them around but when I tried to use them, they were no where near high enough to get under the axle and lift the car. What am I doing wrong? Do you need to carry a block of wood along to put them on or something????
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 11-29-2013, 09:39 AM   #8
Ronnie Lawson
Ronnie Lawson's Avatar
Noblitt and Sparks also made the Model T and Model A flip top jacks.
Ronnie Lawson is offline   Reply With Quote
Old 11-29-2013, 12:13 PM   #9
David31dlxslant
That one doesn't have the hole in the flip top so that one may be model t according to judging standards. Mine has the hole in it just as the walker does which is correct for model a but I guess my biggest question is, is the Ajax acceptable for model a or is the walker the only acceptable model a flip top jack according to judging standards?
Old 11-29-2013, 12:39 PM   #10
RonC
RonC's Avatar
Check the judging standards. If not listed there then it is for another car.
RonC is offline   Reply With Quote
Old 11-29-2013, 01:22 PM   #11
mot
Registered User
mot's Avatar
really ,
the best way is to go to the ford archives and get the blueprint and the engineering releases
that way there will be no doubt
mot is offline   Reply With Quote
Old 11-29-2013, 03:05 PM   #12
mot
Registered User
mot's Avatar
ill try and help a a little better
the jack is part number A-17080
and the handle is A-17081
Old 11-29-2013, 03:56 PM   #13
d.j. moordigian
d.j. moordigian's Avatar
Okay,....now I'm confused, Walker or Ajax..or both, the books show Walker.
d.j. moordigian is offline   Reply With Quote
Old 11-29-2013, 11:32 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
Based on the restoration standards 17-2;
The A-17080 jack made by Walker, was I ratchet type
with a folding 2” top extension and was 10- 1/4" total
height. It was a "carry over" from the Model T Ford
style and was discontinued as a Model A jack about
September 1928. The extension has a 7/16" diameter
hole in each side (unlike the Model T jack which had
no hole) The handle (A-11081) was also a "carry
over” from the Model T. It was made of 1/4" flat steel,
7./8" wide and 16" long. It had a tire iron curve on one
end and a round hole in the other, which lined up with
the hole in the jack sleeve when in use. The handle
was painted black.
It appears that walker was the only one to make 17080 Model A jacks supplied by Ford.
Old 11-30-2013, 05:58 PM   #15
RonC
RonC's Avatar
There are Model T jacks out there where someone drilled the holes in the extension to make the jack appear to be the more desirable Model A jack.
Old 11-30-2013, 07:45 PM   #16
Ronnie Lawson
For Ford Barn 2.pdf
Open the above for more information.
I worked for a company Arvin Industries (was formerly Noblitt and Sparks) that was a tear 1 supplier for Ford Mufflers. We did build the Model A muffler. When we were NS we built tire pumps, hub caps, brake levers, radiator outlet tubes, heaters, mirrors and jacks for the Model A. We had what was called running changes and the prints would not get changed. These running changes would get what was called a deviation. We could produce the product although it was not to part print for so many days. So part prints are not always up to date per production parts deviations. The deviations would not go into the level change box on part prints. Today Ford, Chrysler and General Motors use the same deviation. The deviations today has all three logos on the top header of the deviation.
Old 11-30-2013, 10:14 PM   #17
David31dlxslant
Wow Ronnie, that's a lot of really cool information.
