09-23-2015, 09:38 PM | #1 |
1935 wire wheels
Will 1935 wire wheels fit on an A
09-23-2015, 09:40 PM | #2 |
Re: 1935 wire wheels
Yes
09-23-2015, 09:43 PM | #3 |
Thank you
09-23-2015, 09:46 PM | #4 |
I have done it and went back to original wheels.
09-23-2015, 09:54 PM | #5 |
I sometimes do it twice a week.
09-23-2015, 10:30 PM | #6 |
09-23-2015, 11:01 PM | #7 |
You only need the rings on hydraulic brakes.
09-23-2015, 11:34 PM | #8 |
I'm putting them on a mechanical brake drum
09-23-2015, 11:59 PM | #9 |
09-24-2015, 01:23 AM | #10 |
09-24-2015, 02:38 AM | #11 |
Righto, '35 wheels are totally compatible with orig Model A drums. Be sure and use modern lug nuts, though, not Model A acorn style. The angle is shallower on the acorns and can loosen easily and you'll never know it till you hear a clunking and then the holes are wallowed out.
I especially like being able to run radials from Costco on the '35 wheels. I use P215/75x16. The diameter is 28", close to orig so speedo stays same. Happy Motoring! |
09-24-2015, 08:36 AM | #12 |
Should I be using modern lugs on my '32 18" rims as well jfreddie?
1931 Murray S/W Town Sedan Central Wisconsin Chapter MAFCA |
09-24-2015, 04:51 PM | #13 | |
I looked at their Site and didn't find them. What do they cost? Thank you! Larry |
09-24-2015, 06:01 PM | #14 |
