08-08-2015, 09:00 PM | #41 |
Re: The last and the first
Now that is funny! Do you run ethanol or non-ethanol gas? Can you get non-ethanol gas in Utah? I notice whenever we are in Colorado they have this stupid (IMHO) 85 octane gas and was just in New Mexico and they have it also!
08-08-2015, 09:07 PM | #42 |
Ethanol. There is only one station in the county that sells non-ethanol but it's 88 octane. I don't need octane that high. I run 85. And I don't worry about vapor lock any more since I installed the electric pump. So ethanol vs. non-ethanol is a moot point for me.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
08-08-2015, 09:10 PM | #43 |
Yep, just curious. So you do have the 85 octane, the lowest we have ever had locally is 87.
08-08-2015, 09:13 PM | #44 |
Yes. At higher elevations the need for higher octane is less so the lower octanes are sold that aren't sold at lower elevations and not the higher ones that are sold at low elevations. That means money saving for us at higher elevations because the lower octanes are cheaper. So, a car that the manufacturer says to run 89 octane can safely be run on 87 at our elevation saving money on gas. http://www.aaa.com/aaa/006/EnCompass...r_AutoTalk.htm
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 08-08-2015 at 09:21 PM. |
08-09-2015, 07:30 AM | #45 |
henry it,s the last calf that kills the cow
