07-01-2023, 12:28 PM | #1 |
Coolant additive, will it help?
So before I do a full radiator flush I was wondering if adding something like water wetter to the existing coolant would help or hurt an old flathead. I'm assuming it will hurt it, so I might as well do the flush and figure out something else to keep the engine cool
07-01-2023, 12:32 PM | #2 |
Re: Coolant additive, will it help?
It won't hurt it, but the chances of it curing the heating problem are slim. A properly cleaned radiator in good condition is the best insurance against heating trouble. Nothing against the water wetter type surfactants...they are a decent product.
Terry
07-01-2023, 12:37 PM | #3 |
Great, thanks. I'll just do a flush and clean.
07-01-2023, 12:44 PM | #4 |
Nothing cools better than straight water. However, you do need an anti corrosion agent with a water pump lubricant.
Alan |
07-01-2023, 02:26 PM | #5 |
Fix the actual issue and then proceed. I use norosin in mine. (We don’t get cold enough for antifreeze)
07-02-2023, 09:12 AM | #6 |
