04-12-2013, 08:14 AM | #1 |
eac v. eab
Do they have same size chamber? Same worries w clearance?
04-12-2013, 01:04 PM | #2 |
Re: eac v. eab
Someplace around here I've seen a chart comparing heads by chamber volume in cc's.
Should be able to search it out. Checking clearance is too easy not to do. |
04-12-2013, 02:38 PM | #3 | |
Re: eac v. eab
https://www.fordbarn.com/forum/showth...hart&showall=1 Click on the PDF file at the bottom of the first post. Last edited by KGS; 04-12-2013 at 02:39 PM. Reason: added PDF |
04-12-2013, 02:56 PM | #4 |
Re: eac v. eab
EAC compression is lower than the EAB I belive.
04-12-2013, 06:16 PM | #5 |
Re: eac v. eab
EAC is definitely lower than EAB
Henry |
04-12-2013, 10:13 PM | #6 |
Re: eac v. eab
Drive it like ya stole it! |
04-12-2013, 10:22 PM | #7 |
Re: eac v. eab
Unfortunately the chart tells you the manufactures design numbers. However the actual volume can vary by quite allot. The only way to know is to measure it your self. I have this data in my book.
