03-13-2014, 08:11 PM | #1 |
Head Nut washer use Q....
Does anyone know of any negative effect/reason why hard washers should not be used under flathead cast iron head nuts ? Anyone use this method ?
03-13-2014, 08:38 PM | #2 |
Re: Head Nut washer use Q....
No negative effects.
I use them because an alien friend told me to many years ago. |
03-13-2014, 09:26 PM | #3 |
i dont know of any reason to not use them, they are needed on aluminum heads to stop the head nuts from galling to the head
03-13-2014, 11:33 PM | #4 | |
Heck, that's good enough for me, as I've a bunch of ailing friends also ! I'm betting that you were told by the same alien friends that told big Al G the plans for inventing the computer,eh ? lol I was just wondering if hard washers make torqueing more better mechanically ? That is, hard smooth surface to move on. I'm going to try some on my cast iron head project. Yeah, I agree with using hard washes on aluminum and will be doing so also. Thanks Last edited by hardtimes; 03-13-2014 at 11:34 PM. Reason: ....... |
03-14-2014, 01:29 PM | #5 | |
On stuff like head nuts, main nuts and rod nuts, I use a dial indicator to read torque. I lube the threads also. |
03-14-2014, 03:06 PM | #6 |
For torque, I have four old timey torque wrenches and one brand new Snap On 300 lbs capacity, that I 'borrowed temporarily' from kousin Ron ! |
03-14-2014, 04:07 PM | #7 |
You put an indicator on the end of the stud and measure the stretch as you tighten it.
03-15-2014, 07:36 PM | #8 |
Hm, well when do you know ...when to stop 'stretching them' I'm guessing that I'm stretching them before I'm snapping them,eh? Or mabe they just snap ? Probably have to have some table/whatever regarding stretch and grade of metal/diameter ?
03-15-2014, 09:19 PM | #9 |
Roger on the table info.
