12-11-2013, 02:30 PM | #1 |
40 ford coup rear end question
I am starting on a 40 Ford coup project and was thinking about what rear end to use. I will be swapping to a Ford 302 engine with C4 trans. What Ford 9 inch diff set up would be best for the 40 Ford frame? Or would the later Ford Mustang/Maverick/Falcon 8 inch be a better fit? I am not after super hi performance or drag racing etc, would just want what would fit best. I am going to use the Chassis Engineering kit for the leaf springs shocks etc, and they recommend about a 58 inch housing. I was thinking the 57-59 Fords 9 inch was about 57 3/4 inch if I remember correctly.
Would appreciate any input from anybody that has done this swap in the past with a 40 Ford coup. Thanks, Steve |
12-11-2013, 02:43 PM | #2 |
Re: 40 ford coup rear end question
I have this exact combination in my '40 coupe. I used a '57-'59 nine inch with 2.79 gears, '57 springs on shop built hangers. I'm also running p253/15 rear tires. This combo lets you set the pace on the interstate if you desire. I get 19.5-20 mpg running 70.
I understand the eight inch rears are lighter and reduce the unsprung weight. If you are still searching for a rear, I would try to find an 8 inch. Besides being lighter, they are newer for parts sourcing. Last edited by 40cpe; 05-25-2014 at 09:20 PM. |
12-11-2013, 03:28 PM | #3 |
One of my cars is a '40 coupe with a '57 9" rear on CE springs. Fits nicely! DD
12-11-2013, 03:33 PM | #4 |
I like the ford explorer work great in my 46 with 355 gear and a flathead the best way to go disc. Brakes too
12-11-2013, 03:40 PM | #5 |
The stock Ford rear is 59 1/2 in WMS to WMS. The 1976 ford Maverick rear is s good fit at 58 1/2.. The Ford 8.8 in rear with disc brakes is exactly the same WMS distance as the stock Ford rear except for pinion offset which i think is about 2 in. But they are inexpensive and come with a good selection of gear ratios. Stay away for Versaille 9 inch rears. Big and bulky, overpriced, hard to get parts for and usually come only in highway gears.
12-11-2013, 07:39 PM | #6 |
12-11-2013, 07:41 PM | #7 |
Maverick under my 40.
12-11-2013, 09:33 PM | #8 |
Granada 8" or 9" will fit I have a 8" under my 1940 ford coupe & had a 9" Granada under my 1941 ford pickup. I use the CE spring kit and did not have to move the spring perches. Add the sway bars front & rear to reduce body roll
12-12-2013, 09:43 AM | #9 |
Maverick Under My 40, Had A Granada 8.8 Under My 40 Convert Was A Nice Fit.
12-13-2013, 10:08 AM | #10 |
I used a 59 Edsel and CE springs
12-13-2013, 10:23 AM | #11 |
Well you got allot of answers here and the only disadvantage of the 9" is weight. However, The 5 on 51/2 might bight yoi in the future, We put a Pinto/Mustang under the 40 and that was the best thing we ever did. Unfortunately the bolt pattern is 5 on 41/2
12-28-2013, 08:43 PM | #12 |
Early Bronco in my 40 coupe. 5 1/2 inch bolt pattern and 3.50 gears. 5 inch wide wheels from early 50's F-100 takes up to 235/75 tires and early Ford hubcaps. Sets on Chassis Engineering bolt on parallel springs. Works the balls and everything fits nicely inside the fenders.
12-28-2013, 10:13 PM | #13 |
I like the 8 inch. It's 90 lb lighter than the 9 inch. Plenty strong for a street machine.
12-28-2013, 11:40 PM | #14 |
Got a Granada 8" with a CE kit in my '36, very happy.
