Old 12-11-2013, 02:30 PM   #1
steve fritz
Default 40 ford coup rear end question
I am starting on a 40 Ford coup project and was thinking about what rear end to use. I will be swapping to a Ford 302 engine with C4 trans. What Ford 9 inch diff set up would be best for the 40 Ford frame? Or would the later Ford Mustang/Maverick/Falcon 8 inch be a better fit? I am not after super hi performance or drag racing etc, would just want what would fit best. I am going to use the Chassis Engineering kit for the leaf springs shocks etc, and they recommend about a 58 inch housing. I was thinking the 57-59 Fords 9 inch was about 57 3/4 inch if I remember correctly.
Would appreciate any input from anybody that has done this swap in the past with a 40 Ford coup.
Thanks,
Steve
steve fritz is offline   Reply With Quote
Old 12-11-2013, 02:43 PM   #2
40cpe
40cpe's Avatar
Default Re: 40 ford coup rear end question
I have this exact combination in my '40 coupe. I used a '57-'59 nine inch with 2.79 gears, '57 springs on shop built hangers. I'm also running p253/15 rear tires. This combo lets you set the pace on the interstate if you desire. I get 19.5-20 mpg running 70.
I understand the eight inch rears are lighter and reduce the unsprung weight. If you are still searching for a rear, I would try to find an 8 inch. Besides being lighter, they are newer for parts sourcing.
Old 12-11-2013, 03:28 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
One of my cars is a '40 coupe with a '57 9" rear on CE springs. Fits nicely! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-11-2013, 03:33 PM   #4
HELENT
HELENT's Avatar
I like the ford explorer work great in my 46 with 355 gear and a flathead the best way to go disc. Brakes too
HELENT is offline   Reply With Quote
Old 12-11-2013, 03:40 PM   #5
19Fordy
19Fordy's Avatar
The stock Ford rear is 59 1/2 in WMS to WMS. The 1976 ford Maverick rear is s good fit at 58 1/2.. The Ford 8.8 in rear with disc brakes is exactly the same WMS distance as the stock Ford rear except for pinion offset which i think is about 2 in. But they are inexpensive and come with a good selection of gear ratios. Stay away for Versaille 9 inch rears. Big and bulky, overpriced, hard to get parts for and usually come only in highway gears.
Old 12-11-2013, 07:39 PM   #6
Pete pa
Steve, I have a 39 deluxe coupe 302/c4/gear venders overdrive and 57-59 ford 9" and it is a perfect fit . The 11" brakes stop nice ,you have to move the spring mounts for the CE spring kit. I used 2" lowering blocks and 235/70/15 tires and 7x15 stock Mopar steel wheels they fit real nice under the fenders .
Pete pa is offline   Reply With Quote
Old 12-11-2013, 07:41 PM   #7
okiedokie
okiedokie's Avatar
Maverick under my 40.
okiedokie is offline   Reply With Quote
Old 12-11-2013, 09:33 PM   #8
geoford41
geoford41's Avatar
Granada 8" or 9" will fit I have a 8" under my 1940 ford coupe & had a 9" Granada under my 1941 ford pickup. I use the CE spring kit and did not have to move the spring perches. Add the sway bars front & rear to reduce body roll
geoford41 is offline   Reply With Quote
Old 12-12-2013, 09:43 AM   #9
3340
3340's Avatar
Maverick Under My 40, Had A Granada 8.8 Under My 40 Convert Was A Nice Fit.
3340 is offline   Reply With Quote
Old 12-13-2013, 10:08 AM   #10
biggeorge
biggeorge's Avatar
I used a 59 Edsel and CE springs
biggeorge is offline   Reply With Quote
Old 12-13-2013, 10:23 AM   #11
Ol' Ron
Ol' Ron's Avatar
Well you got allot of answers here and the only disadvantage of the 9" is weight. However, The 5 on 51/2 might bight yoi in the future, We put a Pinto/Mustang under the 40 and that was the best thing we ever did. Unfortunately the bolt pattern is 5 on 41/2
Old 12-28-2013, 08:43 PM   #12
Deuce Engineering
Deuce Engineering's Avatar
Early Bronco in my 40 coupe. 5 1/2 inch bolt pattern and 3.50 gears. 5 inch wide wheels from early 50's F-100 takes up to 235/75 tires and early Ford hubcaps. Sets on Chassis Engineering bolt on parallel springs. Works the balls and everything fits nicely inside the fenders.
Deuce Engineering is offline   Reply With Quote
Old 12-28-2013, 10:13 PM   #13
Pete
Pete's Avatar
I like the 8 inch. It's 90 lb lighter than the 9 inch. Plenty strong for a street machine.
Old 12-28-2013, 11:40 PM   #14
36tudordeluxe
36tudordeluxe's Avatar
Got a Granada 8" with a CE kit in my '36, very happy.
36tudordeluxe is offline   Reply With Quote
