03-11-2024, 02:29 PM | #1 |
hank crank starting rod problem
I attempted to insert my hand cranking rod into the engine and it stops 1 inch from the engine fitting. I suspect that the shaft either has a few high spots or is ever so slightly warped. Yet I cannot see and bending or warping. Any suggestions? Should I sand or grind down the shaft slightly?
