10-30-2014, 03:52 PM | #1 |
Need directional light WIREING diagram 6v pos ground
Diagram needed for electric novice who hasn't the slightest idea of electric WIREING. Your assistance would be most appreciated. John.
10-30-2014, 04:00 PM | #2 |
Re: Need directional light WIREING diagram 6v pos ground
Some more info would be helpful. What year vehicle? Stock wiring? Are you going to use a add on turn signal switch. There are small transisterized switches. The switches usually come with diagrams on where to cut and ad the wires. I use relays and a subminiture center off switch.
10-30-2014, 07:27 PM | #3 |
As Andy said, you first need to decide what you are going to use to activate the turn signals. I, like Andy use a switch setup because I'm not a fan of the add on selectors on the column. But they are the easiest way to go. I would suggest you decide on a selector, order it and then if you don't understand the instructions that comes with it ask a question. If you are interested in a switch setup I can provide you that information. It is not difficult, but takes a little more effort than an add-on.
10-31-2014, 06:46 AM | #4 |
Not trying to steal this thread only Borrow it for a bit !!!
Jseery I would be interested in a switch set up { how does it work } [ I don't mean how well it works ] |
10-31-2014, 10:35 AM | #5 |
These diagrams are not mine, copied for others. There is a lot of good information at the site: http://www.how-to-build-hotrods.com/hot-rod-wiring.html
10-31-2014, 12:35 PM | #6 |
11-01-2014, 11:27 PM | #7 |
Thank you all for input for my 1941 ford coupeSD . Diagrams for switch instal are great also.
