Old 12-14-2016, 10:32 AM   #1
John Kuhnast
Unhappy 1931 shutoff grommet install
Any trick to installing the rubber grommet in the fire wall before installing the under hood shutoff valve.Its putting up a good fight and so far its winning.
John Kuhnast is offline   Reply With Quote
Old 12-14-2016, 01:08 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: 1931 shutoff grommet install
hmm ive never installed one but is it too stiff or is it too small/big?
If its stiff an old trick is to throw it in very hot almost boiling water for a bit to soften the rubber then quickly install it.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 12-14-2016, 01:23 PM   #3
CarlG
CarlG's Avatar
I've done this twice, and it's not a piece of cake by any means. As SeaSlugs suggests, soften the rubber a bit, then in addition, I've used some assembly lube to get things going a bit easier.
Once you finally get it in there, you will perceive a giant smile on your face for having conquered the beast!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-14-2016, 02:34 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Vaseline or WD-40 is a big help with tight rubber grommets. I push one side into the edge of the metal, then use a round end butter knife to keep pealing the rubber inward all the way around. Sometimes I can get by just using my fingers, but often need the butter knife or a similar tool.
Old 12-14-2016, 02:54 PM   #5
Rex_A_Lott
I use spray silicone for most things dealing with rubber.As mentioned, WD-40 if I'm out, but one can of silicone will last a long time.Good Luck
Rex_A_Lott is offline   Reply With Quote
Old 12-14-2016, 03:04 PM   #6
C26Pinelake
Spray Silicone is indeed your answer. And take your time! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-14-2016, 04:40 PM   #7
ursus
I was ready to change out mine, which only has a few small cracks in it. After reading this, I think I will just take car of the cosmetics and leave it as is. If the car is only a driver, it is sometimes better to leave well enough alone
Old 12-14-2016, 10:50 PM   #8
SteveB31
SteveB31's Avatar
When installing rubber around many types of glass (modern windshields etc) , I wrap a small rope in the groove of the grommet, grease it up, and use the rope to pull the grommet in place. Pull the rope out to the inside as you press on the grommet. I have used this method on the grommet and it works easy.
SteveB31 is offline   Reply With Quote
Old 12-15-2016, 12:36 AM   #9
ian Simpson
Use KY jelly. It works well with rubbers. No joke intended.
ian Simpson is offline   Reply With Quote
Old 12-15-2016, 07:06 PM   #10
iverson
iverson's Avatar
I just put on new hood bumpers and didint want to use new rivits so I ground an old junk screw driver shoe horn shape and used soap
iverson is offline   Reply With Quote
Old 12-15-2016, 07:11 PM   #11
bobpo1
bobpo1's Avatar
I heated mine in boiling water, then used some grease for lube, Worked it right in place. GOOD LUCK
bobpo1 is offline   Reply With Quote
Old 12-17-2016, 11:52 AM   #12
John Kuhnast
Thanks heat and grease and its in
Old 12-17-2016, 12:18 PM   #13
2manycars
2manycars's Avatar
Since they were installed in the firewall before the tank was fitted, I can imagine it is very difficult to replace one without removing the tank.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
