11-07-2014, 10:41 PM | #41 |
Re: What is reasonable charge for engine work? 59A
Damn straight!
11-07-2014, 10:42 PM | #42 | |
11-07-2014, 11:23 PM | #43 |
Glad your a happy camper!
Nomad |
11-08-2014, 06:41 AM | #44 |
Did you or the shop determine what was causing the vibration ?
11-08-2014, 08:37 AM | #45 |
Rods and crank out of balance.
11-08-2014, 09:13 AM | #46 |
One of the connecting rods was "odd" and weighed 30 grams less than the rest, so some metal had to come off of all the rest to get them all the same weight. (Metal taken off of the bottom edge of the connecting ring) The crankshaft also needed quite a bit of "adjusting" to be balanced. (Note holes drilled to remove metal to balance) It's no wonder such needed doing when the original crank was missing a chunk of metal at one point from casting problems. Then there was the new clutch I just bought from Fort Wayne Clutch that needed weight added to two flanges to get it in balance. The flywheel was balanced then indexed with the clutch to put together so they'd be balanced together.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
11-08-2014, 09:26 AM | #47 |
Henry:
It's probably a little late for this, but your ring gear looks like it needs replaced. |
11-08-2014, 10:58 AM | #48 |
I've seen quite a few crankshafts with roughness on the back side of the counterweights. There may have been gas pockets inside the molds where the gasses couldn't escape during the poor. The crankshafts were cast in multiples then they were cut apart after they cooled. FoMoCo balanced them but I don't know what there minimum vibration specs were and I don't know what they used for bob weights. Generally they got them pretty close but if the rods are changed then the bob weights also have to be changed and that affects the overall balance. It doesn't look like they took too much off though It's not unusual to do that to get them in good balance. Sometimes they even pour melted heavy metal in the holes to add weight.
That old ring does have some wear but I've seen a lot worse still in service. Last edited by rotorwrench; 11-09-2014 at 10:29 AM. |
11-08-2014, 11:20 AM | #49 | |
I'll keep that in mind for next time.
11-09-2014, 07:58 AM | #50 |
11-09-2014, 08:15 AM | #51 |
Curious - is the main cap safety wire normally done in this fashion?
Looks to be adequately functional but I have never seen a flathead bottom end apart. |
11-09-2014, 09:23 AM | #52 |
About all those flatheads cranks have hunk that looks like it's been broke out but I understand it where the factory brakes it out of the mold. I'm sure there balanced and probably use bob weights and know what the rods and pistons weigh. But now days when we get these engines whey have been built before and rods mix up and pistons changed. SO That is why I have all my engines balanced. Walt
11-09-2014, 10:43 AM | #53 |
I've seen the films that show the cranks being removed from the mold shell and they weren't dainty with them. The casting with sprues and all were dropped down to knock the sand off. A lot of times the cranks would bust away from the tree sprues. What didn't break away from the tree was cut apart. They were just rough ground to remove the flash & protrusions before going on the machine shop.
11-09-2014, 12:02 PM | #54 |
Just curious about the nuts and studs on Ol Henry's main caps. Didn't the main caps have bolts?? John
11-09-2014, 12:46 PM | #55 |
Studs were used until the introduction of the 8BA.
11-09-2014, 03:11 PM | #56 | |
Question for your machine shop really, I'd want them out, sorry. Martin. |
11-09-2014, 03:47 PM | #57 |
Use only a "chasing" tap or die to clean threads. Otherwise, you run the risk of damaging already fragile threads due to annealing caused by decades of hot/cold cycles. As for the surface of the heads and engine deck, there is a big difference between milling and surfacing. Heads and blocks should be carefully checked with a straightedge and, if necessary, just enough material should be removed to restore the surface.
11-10-2014, 02:32 AM | #58 |
The heat produced by a running engine, can't aneal metal parts.
The threads on the factory studs are very good and very strong. Martin. |
11-10-2014, 10:54 AM | #59 |
Scooder, you are quite correct
11-10-2014, 11:05 AM | #60 | |
