Old 10-07-2015, 06:45 AM   #1
glennpm
glennpm's Avatar
Default Generator Stud and Nut Question
Hi,
I am mounting my generator to the front of my manifold using the 9/16" stud and special long nut arrangement. When I took it apart there was no lock washer in my bag. Is one supposed to be used or desired? Also plan to use anti-seize on the threads since I had a tough time getting it off the stud. A few pics below off ebay, and green book. Looks to me that no LW is used on the 42 up generator mounting.
Old 10-07-2015, 07:24 AM   #2
jack orchard
Default Re: Generator Stud and Nut Question
All the 8BAs i have seen have had lock washers. Don't know about other versions. Cheap insurance.,...jack
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 10-07-2015, 04:51 PM   #3
Bluebell
Just as a side note on spring washers. Caterpiller do not use them.
It has been proven that they can cause failures before a properly torqued nut (without a spring washer)fails.
Bluebell is offline   Reply With Quote
Old 10-07-2015, 10:26 PM   #4
A bones
A bones's Avatar
The magic of diesel vibration. For those that don't know, it's extreme and it's relentless
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 10-08-2015, 05:46 AM   #5
glennpm
glennpm's Avatar
Thanks everyone, I'll be using a regular lock washer.
Old 10-08-2015, 07:50 AM   #6
wbedwards
wbedwards's Avatar
Well.... learn something new here almost every day
wbedwards is offline   Reply With Quote
Old 10-08-2015, 04:10 PM   #7
glennpm
glennpm's Avatar
Yes lots of great knowledge and helpful people here.
Old 10-09-2015, 10:00 AM   #8
alchemy
alchemy's Avatar
This summer I had one come loose. I had no lock washer on it, like stock. I fixed what got broke, and drilled the nut for some safety wire, tying it back to the generator mount.
I would say DO NOT use anti-seize on the threads.
alchemy is offline   Reply With Quote
Old 10-09-2015, 12:40 PM   #9
19Fordy
19Fordy's Avatar
I have also been told that spring washers can eventually fail under load. I use a 1/4 in. round steel spacer on top of the square washer so as to make it easier to align and "really tighten" the big nut. 20 years and no problems yet (knock on wood).
Old 10-09-2015, 04:14 PM   #10
glennpm
glennpm's Avatar
Good idea 19Fordy.
Old 01-03-2016, 02:25 PM   #11
big deuce
big deuce's Avatar
Where can a guy find the 9/16" stud?
big deuce is online now   Reply With Quote
Old 01-03-2016, 03:14 PM   #12
luvmyclassics
luvmyclassics's Avatar
so cal hot rods sells them
luvmyclassics is offline   Reply With Quote
Old 01-03-2016, 03:20 PM   #13
luvmyclassics
Sorry- So Cal Speed Shop
