Old 03-29-2015, 11:33 AM   #1
tiger.1000
Default Accessory oil can ?
Some years back someone gave me this oval Ford script oil can. It came with the bracket and fits directly to the bulkhead (firewall).
Anyone know if this was an official Ford accessory or an aftermarket product?
tiger.1000 is offline   Reply With Quote
Old 03-29-2015, 01:57 PM   #2
al's28/33
al's28/33's Avatar
Default Re: Accessory oil can ?
I just mounted one in my '33 engine compartment....sorry the image was turned sideways!!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-29-2015, 02:00 PM   #3
tiger.1000
Thanks Al, however, doesn't quite answer the question.......
Old 03-29-2015, 03:19 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
In USA I don't think so, but I know my Citroen has a place for a can of oil ---but for a different shape can ---welded into the inner fender on a Traction, the D model it fit inside the spare with the jack stand
Old 03-29-2015, 04:29 PM   #5
scooder
That oil Ford oil can is English I believe. Sure it was an accessory for Model Y.
Martin.
scooder is offline   Reply With Quote
Old 03-29-2015, 08:11 PM   #6
Kahuna
Kahuna's Avatar
Hey Als/28 33
where did you get the bracket for the oil can?
Thanks
Jim
Kahuna is offline   Reply With Quote
Old 03-29-2015, 08:28 PM   #7
FrankWest
FrankWest's Avatar
That is great! I love it!
FrankWest is offline   Reply With Quote
Old 03-29-2015, 09:52 PM   #8
al's28/33
al's28/33's Avatar
I believe only the "T"s had an oil can accessory as part of their tool kit........ I hand made my bracket from an old gate hinge and a straight metal back plate with two threaded bolts going thru the firewall.
Tiger maybe yours belonged to a Fordson tractor or later Ford car, sure is a big can ?!?!?!
Old 03-29-2015, 10:03 PM   #9
DavidG
DavidG's Avatar
An original item with Ford script on is not considered "aftermarket" on this side of the pond. Aftermarket here refers to items not made by Ford or made by third parties, but not released by Ford as "authorized". Your oil can was likely not manufactured by Ford, but was released by Ford as "authorized", likely as a service part or accessory sold by Ford to its dealers.
Old 03-30-2015, 01:47 AM   #10
tiger.1000
David.....later today I will take a photograph of the bracket. It was "made to fit" the bulkhead.
Old 03-30-2015, 10:42 AM   #11
tiger.1000
Here's the bracket. Interestingly, the mounting holes in the bracket line up EXACTLY with vacant holes in the bulkhead; as if it were designed for the job ??
Old 03-30-2015, 11:20 AM   #12
DavidG
DavidG's Avatar
Judging from your photo, the upper of the two holes does not exist on original '32 firewalls on this side of the pond and the lower of the two in LHD applications is where the cable for early starter motor switches (mounted on top of the motor) is routed (and plugged when the change to a foot-operated starter switch was made). On North American-sourced RHD chassis, that lower hole was unused on both fours and V8s.
The first photo below is a North American LHD firewall and the second is also North American in origin, but from a RHD four-cylinder vehicle.
Old 03-30-2015, 11:42 AM   #13
tiger.1000
David; when we see warm weather and my back is up to it, I'll remove the bracket and take a photo of the mounting holes in the bulkhead......another as yet unsolved mystery ?
