Old 10-19-2014, 03:27 PM   #1
50mercfan
50mercfan's Avatar
Default 55 ford fender skirt mounting
i bought some after market skirts and clips for my 55 mainline 2 door sedan. skirts fit pretty well. i can't figure out how the aftermarket clips work. anyone have pics?
50mercfan is offline   Reply With Quote
Old 10-21-2014, 06:07 PM   #2
50mercfan
50mercfan's Avatar
Default Re: 55 ford fender skirt mounting
how about pics of factory brakets?
Old 10-23-2014, 09:12 AM   #3
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Just put a set on a '55 Ford for a customer. He picked them up somewhere, but they appeared aftermarket by the hardware. There is a center, L shaped bracket that grabs the wheel lip top center, pulled tight by a bolt from the bottom of the skirt. Front and rear there are bracket type clamps that grab the wheel lip with a bolt and nut that fit through a slotted hole in the skirt. As you tighten those bolts, the clamps tighten on the wheel lip, holding the skirt in place.
streetdreams is offline   Reply With Quote
Old 10-23-2014, 06:26 PM   #4
50mercfan
50mercfan's Avatar
streetdreams, thanks for the reply. unless i'm really missunderstanding, which is very possible, mine dont sound like yours. heres a pic of the brackets. they look they would go behind the lip but they won't fit back there.
Old 10-23-2014, 07:18 PM   #5
streetdreams
The two brackets on the ends with the slots should bolt to the cars wheel lip front and rear. There should be a pin or another bracket bolted to the inside of your skirts to index into the two brackets. Not quite sure how the center bracket in the picture works. A shot of the inside of your skirts would be helpful.
Old 10-24-2014, 09:33 AM   #6
56 Fairlane
56 Fairlane's Avatar
I have a set of the same clips and couldn't figure out how to make them work.
56 Fairlane is offline   Reply With Quote
Old 10-24-2014, 05:26 PM   #7
streetdreams
An inside picture of the fender skirt will be helpful.
Old 10-24-2014, 10:23 PM   #8
Paul H
The brackets in the picture are factory brackets for a 55 or 56.If the skirts you have original equipment they have pins on the front and rear that fit into these brackets.
Paul H.
Paul H is offline   Reply With Quote
Old 10-25-2014, 07:54 AM   #9
rick55
rick55's Avatar
The bracket on the right is secured to the front of the arch lip and the one on the left is fixed to the rear bottom edge.
You need to position the fender skirts and mark on the fender lip where the fixing rods on the fender skirts sit. You may find the brackets need to be ground out a little to let the rod ft in the bracket. I also had to grind the front edge of the brackets to allow them to sit up against the inner lip in the fender arch. You drill holes through the fender lip to screw the brackets in. I had to trim the back lip of my fender skirts as they were fouling the fender lip. Really a time consuming trial and error job. Worth it when done.
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 10-26-2014, 06:48 PM   #10
50mercfan
50mercfan's Avatar
got them on, rick55 nailed it. had to grind a little on the brackets and pound a little on the rods on the skirt to adjust everything. a guy at a local cruise in last night let me take one off on his 55 crown vic and look. that was tons of help. thanks everyone
Old 10-26-2014, 06:49 PM   #11
50mercfan
50mercfan's Avatar
it was a trick getting the dodge lancer caps the clear, but, they fit.
Old 10-26-2014, 07:42 PM   #12
frank long island
frank long island's Avatar
looks good
frank long island is offline   Reply With Quote
Old 10-26-2014, 08:58 PM   #13
rick55
rick55's Avatar
That's a real neat looking 55 Tudor
Rick
West Australia
Henry Ford
