Old 01-31-2020, 09:56 AM   #21
Aretino
Aretino's Avatar
Default Re: Straight Slotted instead of Cross-Point
I replace my straight slot scews with Phillips at each opportunity. Robertson and Torx screws for construction (impact driver). I try to avoid applying to much torque to my model A fasteners.
Aretino is offline   Reply With Quote
Old 02-01-2020, 02:04 PM   #22
Richard Lorenz
I believe that the Phillips screws were designed so that power drivers could be used on the screws in mass production work. This was very beneficial during the World War 2 especially. They "slip" when over-torked.
Most modern Phillips screwdrivers slip too easily. I grind back the tip of the driver in order to prevent slippage.
Richard Lorenz is offline   Reply With Quote
