Old 06-17-2011, 09:15 AM   #41
Ronnie
Ronnie's Avatar
Default Re: The Flathead oil modification thread...
Originally Posted by Merc Cruzer View Post
Any guesses as to what the C.M.P stands for?
Canadian Military Pattern vehicles.
Ronnie is offline   Reply With Quote
Old 06-17-2011, 11:14 AM   #42
Merc Cruzer
Merc Cruzer's Avatar
Now I am getting closer....
File Type: jpg web%202-8%20Beast%20Rebuild%20Camera%20011[1] - Copy.jpg (72.8 KB, 102 views)
Merc Cruzer is offline   Reply With Quote
Old 07-13-2015, 10:46 PM   #43
big deuce
big deuce's Avatar
Originally Posted by BillM View Post
Alternative to the "Grub Screw"; copied this some time ago and don't know if it is still valid.
Is this item still available? Is he here on the Fordbarn??
big deuce is offline   Reply With Quote
Old 07-13-2015, 11:50 PM   #44
JSeery
JSeery's Avatar
Are you asking what a grub screw is?
Old 07-14-2015, 07:30 AM   #45
Ol' Ron
Ol' Ron's Avatar
A 7/16 tap fits through the horazontal plug on the oil pump boss on the back of the block. It goes into the oil passage to the center of the block. This is where the grub screw goes. Run the tap in an inch or so, install a 1/2" 7/16 -14 set screw. simple, easy.
Old 07-14-2015, 07:51 AM   #46
big deuce
big deuce's Avatar
I understand the concept, but I tried to copy and paste the article that Bryan Buckley out of Canada had for his special O ring'd plug.
Old 07-14-2015, 08:24 AM   #47
JSeery
JSeery's Avatar
"O ring'd plug"
That I haven't seen. Not sure I see the reasoning behind it when a simple set screw will accomplish the same thing. Can you post a photo and some information?
Old 07-14-2015, 09:03 AM   #48
Ronnie
Ronnie's Avatar
The o ringed plug doesn't need and tap or drill just a slight press fit fit.You can tap and thread the end of the plug for a future removal.Works very well.I have done a couple and they are still out there cruising away.The plug has a rim on it to limit the installation depth.
R
Old 07-14-2015, 10:37 AM   #49
JSeery
JSeery's Avatar
Ok, that sounds interesting.
Old 07-14-2015, 04:35 PM   #50
Ol' Ron
Ol' Ron's Avatar
More than one way to skin a cat.
Old 07-14-2015, 06:57 PM   #51
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I bought one of those O ring plugs from Bryon Buckley years ago, nice little rig, you don't have drill and tap the block, I think I got his tel no. from the barn. I don't have now. I think it was 35 bucks at the time. Walt
