12-15-2015, 12:28 PM | #1 |
Model B water pump rebuilding
There seems to be lack of availability of Model B water pump rebuilding kits?
Discontinued? Mac's Sells a complete pump but I don't think it is for a 1933 model B, but a 1932 model B because the neck does not slant enough. Has anyone rebuilt a model B pump. Below is pictured the MAC's model B pump...I think 1932 is shown. |
12-15-2015, 12:32 PM | #2 |
Re: Model B water pump rebuilding
12-15-2015, 12:40 PM | #3 |
Also, if you have a good casting and a good impeller you can use the readily available Model A rebuilding parts...you would push the long Model A shaft through your impeller to correct length and play then pin it at that length and saw off the overhang. Bearings and stuff fit.
12-15-2015, 12:56 PM | #4 |
Side question? How is the pulley attached to the end of the pump?
12-15-2015, 01:02 PM | #5 |
12-15-2015, 01:13 PM | #6 |
12-15-2015, 02:23 PM | #7 | |
Short URL: http://smu.gs/14g7eDW |
12-15-2015, 06:06 PM | #8 |
Apart from the shorter pump shaft, be careful as the front bearing and grease seal arrangement at the front of the pump is different on the shortened '33-'34 versions than on the '32 and Model A versions. It is highly unlikely that the sellers of rebuilding kits are aware of that difference and what they are selling is for Model As and '32 pumps.
12-15-2015, 06:54 PM | #9 |
David, what is the difference in the bearing and seal? I looked in the
1937 parts book and it shows the same 28-34, is this a mistake? Bob |
12-15-2015, 08:02 PM | #10 |
I have rebuilt the '32 and '33-'34 versions using NOS or NORS rebuilding kits and never noticed a difference on the front bearing and seal parts. The older Thompson kits had the bearing and seal parts in a small box and were identical in kits for each version.
12-15-2015, 11:17 PM | #11 |
There were two different versions of the felt retainers for the front bearing, B-8540-A and B-8540-B. The latter is shallower than the former and while the former worked fine in the '32 pumps that I've rebuilt, they caused binding in the '33-'34 pumps I've restored (to the extent that even with the leverage of the fan attached the shaft could barely be rotated). Evidently in the rebuild kits only the B-suffix version was supplied.
12-16-2015, 03:29 PM | #12 |
Interesting information. I wonder if the went to the later version for all 32-34 in the rebuild kits?
