Old 12-14-2015, 09:48 PM   #1
rich b
rich b's Avatar
Default '35 3W door glass channel
I have a question on the upper rear glass channel in door. On the one original that was still in the car the upper end of it was not attached to the door. There is a clip on the lower end; but no indication of a clip or screw hole or anything on the top end. It looks like it held in position by the end of the flexible channel that runs up the front and is screwed to the door top. Is this correct? Here is a picture of the piece I am questioning.
Thanks
rich b is offline   Reply With Quote
Old 12-15-2015, 01:47 AM   #2
Pete from OZ
Pete from OZ's Avatar
Default Re: '35 3W door glass channel
Hi rich b
Mine has a small screw at the top which screws into the door top. The flexible channel has the same small screws.
I also pulled the original ones out which did have the small screw at the top. My coupe is a January build.
Pete from OZ
Pete from OZ is offline   Reply With Quote
Old 12-16-2015, 11:41 PM   #3
rich b
rich b's Avatar
Originally Posted by Pete from OZ View Post
Hi rich b
Pete from OZ
Thanks, figured I would add a screw to the top end. Pulled the flexible channel out today along with the screws that used to hold the channel in the other door.
Surprised that the screws were kinda randomly spaced side to side and had four screws on the left and three on the right.
