08-28-2016, 03:21 PM | #1 |
Model T 1915 truck question
Hi. Just joined forum yesterday and posted a detailed question regarding my model T 2015 truck. Was advised that I originally posted incorrectly. Is this the correct way? Please advise so I may again ask question. Thanks much, Tim
08-28-2016, 05:42 PM | #2 |
Re: Model T 1915 truck question
This is the correct section to ask questions.
here is his question; Replaced gas tank that had rotted in 1915 Model T. After 7 to 10 minutes of running the car sputtered, back fired and died. Replaced carburetor thinking it picked up contaminates from old tank. Car has a distributor. Replaced coil and condenser. Problem still persists. There is good gas flow to carburetor and again after 7 to 10 minutes engine sputtered, back fired and died. Sitting for couple of hours will restart but still have same problem. Would appreciate any information, leads, suggestions. Thanks. Tim P.s. With old tank car always ran good! Remove and check for blockage in the line. Make sure the sediment bowl has not got the screen plugged. If all is clear, check fuel flow through drain hole in carb. It should be a good steady flow. Give it a minuet or two don't just open drain the bowl then close again. You may have gotten some blockage in the line from the old tank or some crud has come loose in the process blocking the float needle valve. |
08-29-2016, 02:57 AM | #3 |
" After 7 to 10 minutes of running the car sputtered, back fired and died. ",... "Sitting for couple of hours will restart but still have same problem."
The first thing I thought of was no vent for the fuel tank.
08-29-2016, 12:13 PM | #4 |
Is the ignition stock model t?
08-29-2016, 06:15 PM | #5 |
Yes, it is a new, original style tank. It came with cap with hole in it. I would assume that would make it vented? Thank you for the suggestion.
08-29-2016, 06:22 PM | #6 |
08-29-2016, 06:26 PM | #7 |
This car is stock except for a distributor. I have replaced with a new coil and a new condenser and the problem still persists.
08-29-2016, 06:37 PM | #8 |
You might try a "hot wire" directly from the battery to the coil. The T ignition switches can become intermittent . The back fire might indicate this.
Jack Innes, Brooklin, Ontario |
08-29-2016, 07:26 PM | #9 |
What gas filter did you install? The original under tank or in line. The in lines are notorious for not allowing good fuel flow.
08-30-2016, 04:42 PM | #10 |
I did install a clear plastic inline filter, fuel lines were 5/16 inch. I will try another filter. Thank you.
