01-30-2012, 10:16 AM | #101 |
Re: TOP DEAD CENTER Ford 1946
Dear Henry!
Thank for posting pictures, yesterday I drove for 30 minutes and when I arrived home I tested the next: -cylinder heads 94ºC -radiator water 88ºC -hose out of the water pump 78ºC -botton of the radiator in tubes 86ºC -upper of radiator 90ºC next time I will post picture as you did. thank you very much
I love my Ford V8 1946! Harylufa! |
01-30-2012, 10:28 AM | #102 | |
I set my dist in a manual machine wheel with It degree, with 22º and half as the manual says. I know now that It has 4ºBTDC. Now with a stroboscope should coincide my dist with 4ºBTDC in the pulley marked. I did the mark in pulley because I thought It was necessary to set the timing. I hope you understand me. Thank you
01-30-2012, 11:28 AM | #103 | |
What did your dashboard gauge read at those temperatures?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
01-30-2012, 01:30 PM | #104 | |
It mark in the middle in dashboard gauge. Thanks
01-30-2012, 02:11 PM | #105 |
Well, there you have it. As you can see, the temperature gauges are not even consistent. Mine reads nearly 3/4 at 60C while yours reads 1/2 at 88C. Mine's probably a bit high and yours might even be a bit low. So, we just drive it and if it starts boiling out the radiator cap we stop and let it cool and add some more water and go on down the road. That's about it.
Now, it you hadn't cleaned out your radiator then that is something that you could do. But, since you have, you've done everything you can to keep it as cool as you can and now you just drive it and not worry about it.
01-30-2012, 07:40 PM | #106 | |
I found soot into the exhaust inlet Is it normal, I have been using a bad carb (dodge 1500) for 14 years, Now I have for first time Holley 2100. Can soot raise the temperature in the intake manifold? Is it possible that is full of soot in exhaust manifold? Thank you.
01-30-2012, 07:43 PM | #107 | |
I am trying to discard many possible causes. Concerning the radiator water is almost 88ºC, but I need to discard other thing. Thank you
01-30-2012, 08:12 PM | #108 | |
01-30-2012, 08:16 PM | #109 | |
Ok, thank you!
01-30-2012, 08:16 PM | #110 | |
Be sure to put antifreeze into the radiator water to raise the boiling temperature to reduce the possiblilty of boiling over and prevent corrosion and rust in the engine. You might also put "Water Wetter" or similar into the radiator that might help a very small amount cooling better.
01-30-2012, 09:13 PM | #111 | |
Yes, I did many thing, I hope that sediment into the engine is not the cause of rise temperature. Thank you.
01-30-2012, 09:57 PM | #112 | |
Which carb produced the soot? Soot would be an indicator of a rich mixture which tends to run cooler. If you are not boiling over run it like Henry says. By your temp numbers you are not hitting the boiling point of straight water. If the 2100 is making the soot it may be jetted too rich. The jets should be #51s for a flathead. The power valve should be a 6.5 to 7.5. |
01-30-2012, 10:29 PM | #113 |
I would use .049's and a 5.5 power valve. OMO ken ct. and a leather accelerator pump of the correct length. ken ct.
01-31-2012, 09:48 AM | #114 | |
Nice to hear you again! Please look my valve in other thread. Here is not valve 5.5. Here I can get 4,5 and 6,5 Thank you.
01-31-2012, 10:02 AM | #115 |
You might get by with a 5.0.I use 5.5 and a 5 is pretty close to that.Do not use a gasket on it that has a triangular hole in it ,you need the correct gasket for it.ken ct.usa
01-31-2012, 10:09 PM | #116 |
Dear Henry!
Tell me how is this part called and I attach this parts that is in my car. There was a little hole and I did it bigger. I thought It could be better, am I right? or I did something wrong. Must I make any modification? Thank you
I love my Ford V8 1946! Harylufa! Last edited by Harylufa; 02-05-2012 at 08:40 PM. |
02-01-2012, 01:16 AM | #117 | |
You did not need to enlarge that hole. As long as the fitting still seals so that there is no vacuum leak you do not need to make further modification.
02-01-2012, 05:16 AM | #118 | |
Ok, i should not worry about that hole. The small tube was empty of dust. Than for this info.
