07-12-2022, 03:45 PM | #101 | |
Re: Engine temp rises when I get to cruise speed
Joe you have gone well beyond trying to solve a problem that in my opinion based on my many decades of running supercharged flatheads on the street is being caused by a radiator that's never going to work. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
07-12-2022, 03:53 PM | #102 |
07-12-2022, 06:00 PM | #103 |
Quote from the very first post on this thread:
" I've been trying to cool my car down a little for the past couple of months. When it's 50-60 degrees outside it's not a concern, but as we get into summer here in Jersey things really heat up. It seems that after I installed the radiator the problems started. I had a cheap Ebay aluminum P.O.S. it there last summer and I had no problems" Now why in the world is this problem so damned hard to understand and correct ? Terry
07-12-2022, 06:13 PM | #104 | |
I did check my emails prior to your build > On Jun 16, 2021, at 4:36 AM, Joe V <[email protected]> wrote: > > > I've had no problems with the flex a lite, but I remember you saying the Spal was the way to go. > It's a model 396 S-blade 2500 cfm (if that cfm is true). If you think the Spal will perform better, I'll go with > that, but it needs to be a push type. > I don't have room for a fan to pull. I also already have the relay etc. so I won't need that. > Thanks for your time > Joe At highway speeds 205 deg. “its okay but you're not happy”, you exit the highway and drive 30-40mph at 190 deg. but going back to 45mph you “start to heat up again.” It's not quite the data set I'd like to see but I have suggested you try two offset fans (without a shroud) to see if the additional 1,959 cfm helps below 40mph and free air flow from removal of that shroud reduces your situational overheating above 40mph. Fans matter at ~40mph and lower. You are telling me you will definitely not do this. You removed a SPAL pusher and put a cooling components puller fan in. We recommend SPAL fans because we believe their products are superior to all others on the market. I would not have mounted the puller fan and shroud but since you spent considerable money, I suggest you remove the shroud and you may derive benefit from it. Its four bolts. I am not advocating the removal of fans. I am also not supportive of your coolant changes. There are plenty of good suggestions on this forum but as my particular suggestions do not seem of value to you I am at a loss. |
07-12-2022, 06:34 PM | #105 | |
Let’s stop the bs and either supply a radiator that will cool correctly or tell Joe you will not help him. I have read every comment on here. If straight water won’t cool you have a problem. If you need fans at cruise speed you have a problem. There are hundreds of blown flattys similar to Joe’s that run cool we all know HP = BTUs but even blown these engines in street form do no make excess BTUs. Let’s correct the root cause and get on with our fun lives. Thanks. Cheers Tony. |
07-12-2022, 06:40 PM | #106 |
I would want a system that delivers a temperature between 180 and 190 - and NOT over 195 on a hot day (on the highway) - with your particular 7 lb cap. Yes, you have a pressurized radiator - and that raises the boiling point, but it doesn't do anything about the total heat soak of the coolant. Also, the hotter the engine, the easier it is to detonate it - and with a blown motor, this is even more of an issue. Last edited by Bored&Stroked; 07-12-2022 at 06:48 PM. |
07-12-2022, 06:44 PM | #107 |
I always recommend the largest core that fits. I always advocate pullers over pushers. There is no compelling reason anyone would elect for a thinner core except (1) the incremental cost e.g. $100 or (2) insufficient space. The fact that a pusher fan was used suggests we were told there was insufficient space. I did not measure the space. It was not my recommendation to build a thinner radiator; “expert” or otherwise.
I did check my emails prior to your build > On Jun 16, 2021, at 4:36 AM, Joe V <[email protected]> wrote: > > > I've had no problems with the flex a lite, but I remember you saying the Spal was the way to go. > It's a model 396 S-blade 2500 cfm (if that cfm is true). If you think the Spal will perform better, I'll go with > that, but it needs to be a push type. > I don't have room for a fan to pull. I also already have the relay etc. so I won't need that. > Thanks for your time > Joe Lets get something straight. I was NEVER offered a larger core. As the expert you should have offered or even insisted that I go with a larger core. I told you, as per my above email, that I had a pusher because of no room for a puller. That DOES NOT say I don't have room for a larger core I have over 15K in the set up and building of this motor. Do you think $100 would scare me away from a larger core. I always did things in excess when I put this car together I'm not sure what you're trying to say, but it sounds like you're say I didn't want to go for the extra money for the larger core. I call B.S. sorry |
07-12-2022, 07:00 PM | #108 |
One more comment. A stock 36 radiator has 4 rows of tubes. Why would you build any less in a stock style radiator? Please answer that. I believe a correct stock radiator may cool this engine. Probably 85% of Joes driving produces near stock Mercury HP.
07-12-2022, 08:00 PM | #109 | |
We also increase the fin density for more copper and heat exchange points Ford began doing this in 1932 and again in 1939. You are probably right, Joe should buy a stock radiator. |
07-12-2022, 08:11 PM | #110 | |
Are you going to step up to the plate and correct this issue ? |
07-12-2022, 08:14 PM | #111 |
Joe: Do the removal of the fan/shroud test - then you'll know if the radiator can handle the engine heat at cruise speed. I'd richen the carb first - test it with that, then pull the fan/shroud and test again. Once you see the results, you'll have a good idea as to if you have "enough radiator" for the application.
If you don't then I'd suggest a conversation with Lee to come up with a solution you can both live with . . . versus a stalemate and exploring other vendors. If this doesn't work, then you at least tried. Best of luck, Dale |
07-12-2022, 08:14 PM | #112 | |
Wow what a guy that last line tells us a whole lot about your overall concern. Ronnieroadster
07-12-2022, 08:57 PM | #113 | |
I am not sure how to "step up" and "chime in". I am leaving the forum to go home and yell in my closet. It just makes more sense to me. |
07-12-2022, 08:59 PM | #114 |
07-12-2022, 09:13 PM | #115 |
I'm more interested in a gotcha scenario.
Big respect for responding. For me anyways. |
07-12-2022, 09:32 PM | #116 |
07-12-2022, 09:37 PM | #117 |
07-12-2022, 09:38 PM | #118 |
I find it unsettling that a reputation is worth less these days than a radiator. Then again, with Walker out of the picture, perhaps a reputation is not a prerequisite to selling radiators after all.
Alan |
07-12-2022, 09:47 PM | #119 |
Alan as the internet works. All I have to do is say something and people will gang up even if they have never bought or know what is happening.
Time will tell though. No reason to speculate or condemn a system that might be great for a lot of other applications that are not for some specific moded version. Kinda of limiting a player. But... quick to condemn and slow to forgive. Cancel them? Time will tell. Remember this whole thread is based on one persons motor. . |
07-12-2022, 10:01 PM | #120 |
Maybe every time things don't work out. We shut them down. Leaving us with our d!cks in our hand.
I think that's how Don Prudhomme did things. When it didn't workout he posted on social media. If you are questioning what rads I run, They are re cores. Not sure I could find some one today that could do it now. Never have purchased or worked for Brassworks. Probably the best bet is they can give him his money back and walk away. Just my opinion. . Last edited by Tinker; 07-13-2022 at 12:28 AM. |
