09-07-2011, 01:04 PM | #81 |
Re: 1937 No start
Thank you all for the help - many minds = many outlooks on same issue - sometimes we all develop tunnel vision and need a new perspective - again -Thanks.
09-07-2011, 01:20 PM | #82 | |
Re: 1937 No start
09-07-2011, 02:01 PM | #83 |
Re: 1937 No start
To double check any internal timing when at TDC turn 1 full turn at that time the intake starts to open and about 6degs later the Exhaust closes.
The car did run so i doubt its in side. |
09-07-2011, 02:20 PM | #84 |
Re: 1937 No start
Answer to post 76 NO, and dont waste your time pulling the heads. Here is a picture of what it should look like. If your cam is installed correctly like you said it was the system looks like this. The next picture is of the correct position of the distributor rotor. The rear rotor contact points approximately 11 o'clock and that is the number one spark plug wire. The distributor rotates counter clockwise and the front rotor then indexes to fire the #5 cylinder which is the front cylinder on the driverside, that is on the front terminal contact at about the 7 o'clock position marked 5 on the driver side cap. Looking at the distributor the the front rotor contact would be pointing down towards the 5 o'clock position. I still think you need to check the wires in the cap for the correct sequence.
dickspadaro.com |
09-07-2011, 02:42 PM | #85 | |
Re: 1937 No start
Hoop, I have two 37 distributors and I noticed previously that the distributor caps were different and didnt think too much of it. are you saying that these particular distributor caps have to work with a particular rotor and that they are not interchangeable? I guess luckily i never mixed them up....thks bob |
09-07-2011, 02:56 PM | #86 |
Re: 1937 No start
Maybe just a coincidence ... 45 degrees .... what's 360 degrees divided by 8 (cylinders)? That's one whole spot off ... ? Bob, 37forddr, early and late have two different part numbers but haven't had time to check to see if the early one will slip into the later case. The tabs fit into different slot locations ... for the time being consider I don't know what I'm talking about. Edit for additional info: Found some early terminal caps, the inside ones. It is possible to fit these into the later case. If so, the #1 plug wire will be in the forward top position ... 45 degrees off. The tabs are different, but if someone were not aware that there might be a difference, could make it go together. Late terminal caps should have a part #68-12113. My early ones have no number but it should be 18-12113. I suggest looking for the part number on the inner side toward the rotor. Would definitely cause the problems described.
"Remember that when it comes to intelligence, half of all of us are below average." Last edited by Hoop; 09-07-2011 at 03:26 PM. |
09-07-2011, 03:32 PM | #87 |
Re: 1937 No start
Dick Now thats what i was looking for.If you were to look from side with rotor to you and draw a staight line the wide clot would be farthes and small end points to you.
Or wide slot at 12 oclock and rotor a 6 oclock. Its this correct. |
09-07-2011, 03:54 PM | #88 |
Re: 1937 No start
Car was starting and running then ,not starting when warm ( as a result of the coil or condensor ) After rebuild of dizy will not start at all . You should Swap out the distributor. bad or wrong rotor (37type ).or points timing .It did have a new faulty condenser put in it . ??
Car was starting and running fine - then - started to be hard to start and would start and run BUT then when warm would not start - SO I checked for fuel, air, spark and there was NO spark at all coming out of rotor / distributor - so I sent distributor out to VanPelts for overhaul - got it back and now will just pop thru carb - then I took dist. off of car and put in vice and ran aux. pwr to it and there was internmittent spark and it was orangish - so I swapped out condenser, which was new with dist. overhaul, and got nice steady bue / white spark - as you can see by my replies I am trying to keep updated as I try things out. Thanks. Last edited by FlatheadTed; 09-07-2011 at 04:11 PM. |
09-07-2011, 03:59 PM | #89 |
Re: 1937 No start
Sure sounds to me like the original problem was a BAD condensor and now mixed parts have caused the rest of the problem. Sure would be good if you could borrow a running car dist and conduits to check things out.
09-07-2011, 04:11 PM | #90 | |
Re: 1937 No start
09-07-2011, 04:27 PM | #91 |
Re: 1937 No start
Did Mac install new inner caps or did you use your old ones.You can tell if their the right ones by installing 1 side and leave the other side open [no caps] Look through the contacts on the inner cap should line up with the blade of the rotor when you turn the toung by hand. They will almost touch on the way around.If not you have the wrong inner plates.Just hunting all possibilities.Rotor bakealite rotor must have like steps on it not smooth like earlier ones 36 and down. ken ct.
09-07-2011, 04:36 PM | #92 |
Re: 1937 No start
Point of information, You cannot mix contact caps between early and late design The spacing and indexes are different to the point that they will not work together, The early 32-36 contact caps index pin positions between the wide portion of the contact pins and the 37-41 cap has the index pin located between the narrow side of the contact cap. So they could not be incorrectly installed.
dickspadaro.com |
09-07-2011, 05:17 PM | #93 |
Re: 1937 No start
Based on Hoops last post, I just remembered that a friend of mine had once inadvertently put the later '37 inner/terminal caps in his '36 distributor and his engine ran or tried to run very poorly. It is possible that you have the reverse scenario, '36/earlier inner caps in a '37 distributor. It is now sounding a lot like something is not right with that rebuilt distributor. If you only had a known good '37 distributor that you could put on temporarily to try it out.
When this '37 finally gets fixed and runs well, we should all go and have a beer together. Edit note: Well....based on Dick's last post my friend did the impossible....I guess
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 09-07-2011 at 05:26 PM. |
09-07-2011, 05:46 PM | #94 |
Re: 1937 No start
dick spadaro is dead right about the caps the early & late are indexed different. but knowing what people are capable of who knows
09-07-2011, 05:46 PM | #95 |
Re: 1937 No start
OK , i would have to agree that nothing is worse than a engine that wont run , we have all had them and 99.9% of the time its something simple.
After almost a hundred replys heres my offer. Send me your address and i will build you a fresh 37 distributor ( with a twist), mine will use a remote coil, coil wire and come to you assembled with coil adapter, coil ,condensor and coil wire. (no charge) All you need to do is install, run a single battery wire to the coil power lead and crank the engine using your caps and wires . This will aleviate the distributor, coil etc that you are using now. If the engine now runs send me the unit (complete ) on the car now and i will disect, fix and return.... Fair enough ???? Can get it out to you tomorrow afternoon......... I have got to assume that the wires after this much work are correct . |
09-07-2011, 07:56 PM | #96 |
Re: 1937 No start
I have seen several rotors that were shorted through to the shaft??? G.M.
www.fordcollector.com |
09-07-2011, 10:02 PM | #97 |
Re: 1937 No start
sounds like distributor is set up wrong....or something is wrong with the distributor....take Bubba up on his offer and then you'll know whether it is the distributor or not...hopefully....good luck....Mike
09-08-2011, 12:08 AM | #98 |
Re: 1937 No start
,I am sure Mac does a great job but any thing can happen with theses old cars its just something to look at .GMs right about Rotors . Here is a picture of two Rotors the large one #@*32 to 36 held me on the road for two hours the customers 34 just would not go up a hill it just crackled and popped . .I had limited tools on board, but with the aid of finger nails as screw drivers I managed to get the Dizy of and put tape around the shaft like so. and get home it went like a train.the rest of the way ,
09-08-2011, 04:50 AM | #99 |
Re: 1937 No start
Marc, just double check the part numbers on the inner terminal caps and eliminate that possibility ... humor me.
"Remember that when it comes to intelligence, half of all of us are below average." |
09-08-2011, 08:55 AM | #100 |
Re: 1937 No start
Note If there is one bad one be on look out for more,just think 100 more pieces of junk.
