04-20-2024, 10:06 AM | #61 |
Re: Magneto and belts
On the HAMB look up GRISWOLD MAG.
04-20-2024, 03:14 PM | #62 |
I has invested allot of time ( money ) in my magnet and decided cam ( 8AB ) plus this is a short angle drive and has also its own issues on fans and belts.
04-22-2024, 09:47 AM | #63 |
The belts that was used ex 78-8620-A is little over 5/8”, but when did the smaller belts came into US production, like we see on cars from the 60’s and 0.44” wide.
In my case if those belts would work in the wider grooves and is ’time correct’ etc early 50’s it save me some space vs the 59 pumps and the 8 camcover. Ideas. Last edited by 3W Hank; 04-22-2024 at 10:55 AM. |
04-22-2024, 02:43 PM | #64 | |
The narrow belt came on the Ford 8BA in 1949 for the engines used in some passenger cars. The wide belt continued being used for the Ford trucks in 1949 to 1953. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
04-22-2024, 06:02 PM | #65 |
Will the narrow belt fit on the wider pulleys ?
