Old 02-11-2012, 03:16 PM   #41
all american boy
all american boy's Avatar
Default Re: 1960 f100 with 292 yblock which auto trans to use?
56 custom
oh no! mr bill!
i'll post one of my pic's
when i stop laughing.
your's is as grungy as mine.
LOOKOUT '56!
when i posted my pic's i had soreheads
getting pretty nasty because nobody could see anything.
ok.
so far it does look like mine.
that's good!
this has been worth waiting for!
Have A Nice Day!
'Has racing made you a millionare?'
'Yes it has.Before I was a multi-millionaire.'-Quote
all american boy is offline   Reply With Quote
Old 02-11-2012, 03:26 PM   #42
56 ford custom
So mine is a cruis o matic?
56 ford custom is offline   Reply With Quote
Old 02-11-2012, 03:29 PM   #43
all american boy
'56 custom
BEFORE you disconnect anything!
where do the 2 cooler lines WITH TRANS FLUID IN THEM go to?
mine has 3 fittings on passenger side of main case.
2 upfront by bellhousing HI and LO.
1 at rear of main case LO.
all 3 on the passenger side!
Have A Nice Day!
Old 02-11-2012, 03:32 PM   #44
all american boy
'56 custom
to answer your 'pointing at question'
hang on let me look at your pic's again.
does it come out of front HI?
i went out and looked at mine.
Have A Nice Day!
Old 02-11-2012, 03:50 PM   #45
all american boy
'56 custom
so far, yes.
it looks like cruisomatic.
i am trying to help you here.
save you time in the end.
does the line you pointed at
come from front HI?
Have A Nice Day!
Old 02-11-2012, 03:51 PM   #46
56 ford custom
Hi?
Old 02-11-2012, 03:59 PM   #47
all american boy
'56
on passenger side.
2 fittings on mine AT FRONT are 'ONE ABOVE THE OTHER'
that gives a HI and a LO one.
1 fitting at back is all by it's lonesome and LO (low on case, near bottom)
is pointed at tube coming out of FRONT HI (high) fitting/tapped hole?
bob
Old 02-11-2012, 04:08 PM   #48
all american boy
'56
here's pic of mine.
one line on the left and
two on the right.
two on the right.
one is 'upper' and one is 'lower'
where does your line you pointed to
go to?
bob
Old 02-11-2012, 04:31 PM   #49
56 ford custom
I will have to check on it
Old 02-11-2012, 11:19 PM   #50
Paul H
AAB,
If the transmission in your 64 is original to that vehicle,it's a COM.The two fittings on the side are for cooler lines.The fitting on the lower rear is for a vacuum modulator.The modulator screws into that fitting and a vacuum line runs from there to an outlet on the intake manifold of the engine.
56 Ford Custom,
The FOMs did not have a vacuum modulator.An air cooled FOM would not have any fittings on the case for cooling lines.FOMs made after mid-56 do have fittings for cooler lines,but not for a modulator.
Paul H.
Paul H is offline   Reply With Quote
Old 02-12-2012, 03:20 AM   #51
56 ford custom
Thats some good info. I would really like to know what my two transmissions are. So ai get get this truck and car put together.
Old 02-12-2012, 03:56 AM   #52
all american boy
'56
how about saying which fitting the
line you were pointing to goes to?
if it goes to either one of front 2 fittings
and which one, upper or lower?
bob
Old 02-12-2012, 04:15 AM   #53
all american boy
'56
after you find which fitting the line
you pointed to goes to do this:
1 the two lines on TOP of cooler are
are the fluid lines.
they SHOULD go to the REMAINING 2 fittings on
side of trans.
2 now you clean trans
3 take off cooler and trans lines and water lines.
you're not putting them back on.
4 get 2 brass barbs from napa and 2 feet of black fuel hose.
5 put the barbs in the 2 TRANS FLUID fittings.
bypass the trans cooler for now.
6 put the engine and trans back in truck.
7 get a trans temp gauge from napa
drill a hole in trans pan. put the sender in.
8 drill a hole in floor
9 put the gauge on a rag on the floor
Have A Nice Day!
Old 02-12-2012, 04:18 AM   #54
all american boy
'56
monday morning you call Charlytranny.com
http://www.charlietranny.com/
ask him if your tranny will stay in safe temperature range with
TRUCK TRANS COOLER W/WATER LINES removed & bypassed.
also ask him if fuel line will hold trans line pressure.
the extra line left over i'm 90% sure is VENT.
Have A Nice Day!
Old 02-12-2012, 04:33 AM   #55
all american boy
'56
about that truck trans cooler
i read that is to WARM THE TRANS UP!
it's for when the temperature is 10 degrees outside.
engine water will get warmer faster than
trans fluid.
i live in california so bye-bye to that warmer/cooler on my trans.
your truck will drive with the bypass.
i guarantee you that you can test that tranny w/bypass hose setup.
if you want to put trans warmer/cooler back on later.
go for it!
Have A Nice Day!
Old 02-12-2012, 09:55 AM   #56
56 ford custom
So if im going to be gettubg rid of it should I use the other trans?
Old 02-12-2012, 11:20 AM   #57
all american boy
'56
just leave the warmer/cooler off.
use the transmission you've posted pic's of.
you're ready to put it all back together!
bob
Old 02-12-2012, 11:30 AM   #58
all american boy
'56
i would clean tranny real good.
i figure you have a pressure washer.
gunk and a hose with good water pressure will work.
for this get 4 or 6 cans.
use GUNK BRAND-ORIGINAL FORMULA.CHECK CAN BEFORE YOU BUY.
let the gunk do the work.
soak grunge real good.
leave it for 10-20 min.
come back and spray it.
bob
Old 02-12-2012, 12:04 PM   #59
56 ford custom
Im sorry if I seem slow. Its just I have nno idea how to bypass or not use this cooler or warmer. Im nervous about doing that. I dont want to mess anything up.
Old 02-12-2012, 12:12 PM   #60
all american boy
'56
not at all.
follow cooler lines from
warmer/cooler to fittings.
draw yourself a little picture.
where two lines go in tranny.
doesn't matter which is pump out & return.
then you're ready to START CLEANING!
before you put tranny back in
hook up 2 feet of hose.
bob
