03-18-2024, 12:35 AM | #41 |
Re: '35 gas tank yuck
03-20-2024, 06:13 AM | #42 |
I bought the por15 tank cleaner kit for my roadster. After 10 minutes of shaking I started to get acid dripping on my feet. The rust was just too deep!
03-21-2024, 05:30 PM | #43 |
the senders 12 volt gm style come with the 5 to 6 adaptor
then you can run an aftermarket gm fuel gauge the benefit here is the OHMs rating will be the same i.e. you will get a correct reading note IF you buy a poly plastic tank, the central losenge prevents the long length of the rod and float, buy the stainless steel version. if its a pickupo 37 you need the one with the filler into the corner. |
