11-29-2015, 11:37 AM | #41 |
Re: Battery cut-off
I like the Caterpillar switch, 125A Continuous, 1000A Intermittent duty, keyed, reasonable price.
http://www.tornadoparts.com/caterpil...switch-7n0718/
11-29-2015, 11:42 AM | #42 | |
Re: Battery cut-off
11-29-2015, 06:53 PM | #43 |
Re: Battery cut-off
I once saw a popout cable glowing,it was the only ground path that was working at the time.I have seen discolored fuel lines,and found later that they had been the primary ground for the starter.If the rear mounts are installed properly there should be zero juice passing through them.
11-29-2015, 07:04 PM | #44 |
Re: Battery cut-off
With all this talk of poor grounding, it is important that the frame connection be clean and correct. I like to add an extra heavy cable from the frame to the transmitter.
11-29-2015, 09:43 PM | #45 | |
Re: Battery cut-off
Here are pictures of my '30 roadster install. Sanitary, out of sight and pretty easy. Best part is that it can be switched in about a second from sitting position, if emergency occurs. Think safety first when driving an antique car with possible wire shorts, etc.... First thing turned on when starting car and first thing turned off when leaving car . Fool proof |
11-29-2015, 11:34 PM | #46 |
Re: Battery cut-off
11-29-2015, 11:36 PM | #47 |
Re: Battery cut-off
11-30-2015, 09:02 AM | #48 |
Re: Battery cut-off
11-30-2015, 09:08 AM | #49 |
Re: Battery cut-off
Just so everybody is clear on this, a battery cutoff switch alone is NOT a safety shutoff! The engine will continue to run, with the genny or alternator powering the entire electrical system- even if you have a hot smoking short circuit.
If also want it to function as an engine kill to stop generated power to the electrical system you need a double pole switch like this: The heavy lugs break the battery. The smaller (rated 20A) are wired to break the ignition and, if you have them, electric fuel shutoff and fuel pump. THAT stops the engine in an emergency and in turn stops the running genny or alternator from powering a damaged electrical system independent of the battery. If you have an alternator you need to be careful not to wire this switch to break the entire alternator output from the output lug. That is usually fatal for the alternator. Many racing sanctions demand this type of switch and they can also be wired into the alternator internal circuit for a safe instant kill as an alternative to splicing into the ignition and fuel supply. Of course, in a running engine electrical emergency you could just remember to shut off BOTH the ignition and battery, but this dual switch makes it simple. |
11-30-2015, 10:28 AM | #50 | |
Re: Battery cut-off
12-01-2015, 10:34 AM | #51 | |
Re: Battery cut-off
This could be the cause of many reports of vapor lock that we hear of. The fuel lines I'm talking about.
Terry Quote:
11-06-2018, 09:21 AM | #52 | |
Re: Battery cut-off
Tinkirk Terry |
11-06-2018, 09:41 AM | #53 |
Re: Battery cut-off
ive been using the red handle with good luck . I break the neg side (less arching) from the battery , no power anywhere . mounted in cab below seat , out side would be a hassle & waste as anyone could use it . BUT I do have an emergency switch (hidden well , even from me at times) because I have electric door & trunk …………… alls good
V4f |
11-10-2018, 07:08 PM | #54 | |
Re: Battery cut-off
I also use this on both of my rigs. Has worked well. I think you can get the kit from most all of the vendors.
Fred Kroon 1929 Std Coupe 1929 Huckster |
11-11-2018, 02:22 PM | #55 |
Re: Battery cut-off
I pull the fuse that has been added to the top of the starter. I k now that this does not disconnect the starter power, but disconnects all other power.
What are the downsides to this? Most issues seem to be caused by generator/cutoff and lights-wring-switch issues from what others have posted. |
